Old 02-04-2011, 10:58 AM   #1
laphan's Avatar
Originally Posted by BYprodriver
This is typical of Boxster clutches as well as what you are reporting OP. The T/O bearing wears away the grease on the pressure plate fingers & then it wears the fingers flat instead of rounded. Replace your clutch with a stock Sach as soon as you can & check your IMS bearing while the trans is out.
Yes, I'm replacing the clutch with OEM clutch kit (including TO bearing and trans input seal), RMS, LN IMS upgrade, AOS (better access when trans removed), brake/clutch hydraulic fluid, trans oil change and all 6 spark plug + 6 tubes with total damage close to $3K with labor and tax....
laphan is offline   Reply With Quote
