01-25-2011, 12:16 PM
How to Polish Exhaust Tips
Can anyone tell me a way to get a high polish on the stock exhaust tip on my 2004 Boxster. I have tried metal polish, by hand, and 000 steel wool but I still end up with the dull finish. Any ideas are appreciated!
01-25-2011, 12:30 PM
How to polish exhaust tips
Dave,
I happened to come across this cloth applicator dipped in some kind of oily polish, and it really worked well. it is multi use so i've have it for the last 2 to 3 yrs now.
i know it's no help for you without knowing the name or where i got it from.. but just in case i find out i will surely share them in the forum.
for the meantime i think using a polish called "SOL" would be worth trying..
thx,
t2 04S
01-25-2011, 01:57 PM
000 steel wool will create a satin finish all day long; even 0000 will not polish. I've used Blue Magic and a dab of 3M hand glaze to polish all sorts of metal pieces, including my exhaust tips; however, I don't want bling back there, but it does produce a decent shine (I used to be involved with the concours crowd, but lost interest when I really learned to drive).
You're going to have a bit of work ahead of you, so be prepared.
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
01-25-2011, 02:46 PM
Try Eagle One wadding polish. It's a can of soft fibrous stuff with petroleum distillates.
Slow but effective at removing the grime.
01-25-2011, 03:51 PM
A gent on here recommends Showman's................my tips are now black ceramic so no need!
986 00S
01-25-2011, 05:28 PM
'13 S - Guards Red / Luxor Beige - Options - Loaded to the Hilt!!
'01 S - Guards Red / Beige - Surrendered - 04.18.12
01-25-2011, 06:28 PM
Use Blue Magic. Take the tips off, lock them down in a vise and use steel wool to smooth out the brushed stainless. Then pull out a drill with a buffing wheel and put on a shine that will look like chrome.
I did and it is a nice touch in the back of the car.
01-25-2011, 08:09 PM
Can you take the tips off on 2000 Base?
I couldn't find anything there to dis-assemble
Sasha
01-26-2011, 06:38 AM
Visit your local Honda motorcycle dealer and get some Honda metal polish. It works excellently on stainless steel. No power tools needed. Here are a couple pics of a BMW stainless exhaust. It works equally well on the Boxster tip. I don't know what's in the Honda polish but it is the right stuff for stainless exhausts.
01-26-2011, 12:22 PM
Gator Bite
PCA Cayman Register Advocate
01-26-2011, 12:37 PM
More on polishing Stainless Steel
I dug up some more pictures I can use to help demonstrate what's possible with polishing stainless steel.
This is a Borla exhaust, out of my 2007 Cayman S.
It has about 5,000 miles on it, and it's pretty disolored. This won't do because I had entered the car in an exhaust competition. If you look at the rear pipes, then look diffrerent, smoother than the rest of the system. That's because I polished them before I put the system in, but only from the back of the mufflers back.
Closer to the engine, and the discoloration is brutal.
Gator Bite
01-26-2011, 12:43 PM
Continuation
But don't worry. Stainless can be brought back from the brink of dissaster when you have a bufing wheel and the right compounds.
Here's a demonstration on the worst spot of the pipe, so you can see the progress.
Buffing is a two stage process. First there is the cutting stage. In the cutting stage you use a very coarse compound on a wheel that actually removes the top layer of material like a sanding wheel, leaving a nice brushed surface below.
Then comes the 'coloring' phase. For this you switch to a soft cotton wheel with a
very fine compound that really brings the shine out.
Can you see my reflection in the pipe.....? Well, don't stop there. Keep on going and you end up with this:
Gator Bite
02-08-2011, 07:45 PM
Autobahn Glanz
Gator Bite, these pictures are awesome. One of my next projects is to do my dual tips on my 'S'. So do you just use a cotton buffer on a drill and go from med to fin compound? I also noticed my tips are welded on so I guess I have to work on it while on the car.
02-09-2011, 06:36 AM
A drill isn't the best tool for this. A small motor is much better. You can even convert a bench grinder. I've done miles of buffing using an old motor out of a washing machine. Anything from 1/4 hp up. On stainless, 1/2 hp or more is best, somewhere around 2,000 - 3,000 RPM.
You can get lost of cheap buffing supplies here: http://www.caswellplating.com/buffs/
No affiliation. I've used them. They have OK stuff, good prices, lots of knowledge.
Gator Bite
