Old 12-31-2010, 08:17 AM   #1
Andrew McD's Avatar
Rear drivers side screech...
Hi,
Just been for a spin and all well. I parked up and came back to the car an hour later, when I drove off there was a screeching coming from around the rear drivers side wheel. It sounds a little like metal on metal. I thought a stone had got stuck in between the pad and disc. It was not there when the car was idling and did not seem to be effected by braking. After about half a mile it had gone. Any ideas???
Thanks, Andrew.
Andrew McD is offline   Reply With Quote
Old 12-31-2010, 08:38 AM   #2
seningen's Avatar
possible wheel bearings?
mike
Drivers: '15 Panamera Hybrid (wife's), ' 01 996 GT2, 00 Boxster S, '96 993 Çab/Tip (wife's)
Race Cars: '75 911 RSR Replica & '99 Spec Boxster
mike@lonestarrpm.com
seningen is offline   Reply With Quote
Old 01-01-2011, 09:26 AM   #3
jcb986's Avatar
Right side could be a wheel bearing, a rock lodged somewhere at the parking brake, an axle bolt coming loose, air intake fan. Keep an eye on it and inspect anything you can so you can rule out possibilities.
Old Hippie Young Heart
jcb986 is offline   Reply With Quote
