Old 12-24-2010, 01:19 PM   #1
Another key fob question
Sorry to post another key fob question, but after about an hour of searching through and reading, I still didnt see the problem I'm having.
Key worked fine about a year ago. It gradually started intermittently not working so I would have to manually open the doors. Since then, I replaced the battery. Didnt seem to make much/if any difference.
Now when I press the key, the red light doesnt flash rapidly like it used to, it flashes once every two seconds. Has this ever happened to anyone? Did I just happen to buy a weak battery that is almost dead already or is this some kind of other problem?
http://i67.photobucket.com/albums/h3...IMAG0137-1.jpg
00 S Triple Black- Smoked lights, Tinted windows, Stainless exhaust, IwireP ipod cable, desnorkled, painted bumperettes
Jake D is offline   Reply With Quote
Old 12-24-2010, 02:33 PM   #2
Mine too
Hi this happen to me exactly the same , key use to work , than not working once in a while , out of a sudden totally not working .
When i press the buttons , it no longer flash rapidly, but instead it flash about once per seconds .
Anyone had any idea whats going on ?
TIA.
brabus is offline   Reply With Quote
Old 12-25-2010, 05:54 AM   #3
Changed the battery again, and still have the same problem. after looking at the key closer, it looks like there is a decent amount of corrosion under the plastic battery holder. Not sure if unsoldering the battery holder, cleaning it and putting it back together would help/work, but ill probably give it a try since it looks like its worthless as of right now
Old 12-25-2010, 07:10 AM   #4
Subscribing in case an answer develops. I learned something new reading this thread. I have one working and one non-working remote and I didn't realize they flashed differently. The working one flashes in a pattern really fast while the non-working remote blinks at a slow steady interval. Seems to be just like the OP.
I revived an old thread a few days ago where somebody said they had a method for reviving communication between the car and and a non-working remote but it didn't work for me or the others who replied.
Dale_K is offline   Reply With Quote
Old 12-25-2010, 09:04 AM   #5
I don't have any problem with my key fobs, but I have had my car for 4 years and I am sure the battery is geeting low.
Can I open up the fob and replace the battery (CR2032??) without losing any programming code and having to reprogram everything? Thanks.
Soetekouw is offline   Reply With Quote
Old 12-26-2010, 01:12 AM   #6
I've replaced my battery, cr2032, without problem.
Dale K: seems your key fob has a couple of issues. If you can resolve the difference in flash frequency, you might want to try the fix I posted again. It did work for me, albeit some time ago. Both of my fobs flash normally.
jotoole is offline   Reply With Quote
