Old 12-21-2010, 11:04 AM   #1
What does that process run normally? does the engine have to be pulled?
Thanks for the input.
-John
john90290 is offline   Reply With Quote
Old 12-22-2010, 01:00 PM   #2
Update- Problem solved...
Put a quart of ATF in the oil, ran for 30 miles, noise gone, lifter loose. Changed oil and filter today, quite as a mouse. Read about this fix on other forums and heard about it back when i was working on Alfa's. I can say it worked. :dance:
Old 12-23-2010, 09:30 PM   #3
How did ATF oil fix a Loose lifter?
wouldnt think 1 qt of ATF in with 9 quarts or motor oil would be enough to even do anything?
dirkdiggler is offline   Reply With Quote
