Old 12-20-2010, 04:46 AM   #1
What To Replace While Engine/Trans Out
Planning on having the IMS changed on a 98 Boxster with tiptronic, 26kmiles. Have been told that engine/trans have to come out to do so. Figured I'd change these parts at the same time:
underdrive pulley for ps
water pump
low temp thermostat
AO separator
spark plugs/tubes
after market exhaust
Any suggestions as to what else may be good to change out at this time?
Thanks, Rob C.
996tt2002 is offline   Reply With Quote
Old 12-20-2010, 05:54 AM   #2
JTP
RMS, trans fluid and service, motor mount.
JTP is offline   Reply With Quote
Old 12-20-2010, 06:18 AM   #3
Check the wiring to the cam position sensors, it can chafe and wear through. May not need to replace, just add another layer of protection with a high-temp wire loom like this: wire loom.
Coolant expansion tank. Replace if yours has yellowed. As the color changes due to age/heat/chemical exposure the tank weakens and is more likely to crack.
-- John
'00 Boxster S
'86 911 Carrera Coupe (Sold)
Lucky is offline   Reply With Quote
Old 12-20-2010, 07:32 AM   #4
With your other mods you may want to update to a Caymen motor mount.
2000 New Beetle / in search of 03 986S triple black
Caractere kit seam sealed, Caractere rear wing, 1 3/4" drop on coilovers, 235/40/18 Kuhmo XS on 18x8 Millie Miglia Spider II's, H2sport spindles, H&R front Sway bar, O-bar rear torsion, VF Eng. motor mounts, G60 12# flywheel, Nuespeed P-flow intake, Forge DV, Samco IP, Custom K04 turbo and Upsolute chip, 4 bar fpr, TT 2 1/2" SS DP, 2 1/2" custom stainless exhaust no muffler, Peleguin LSD, B&M SS, Momo 14" wheel, R32 steering rack.
yelojkt is offline   Reply With Quote
Old 12-20-2010, 08:05 AM   #5
Good suggestions! I had thought about the motor mount but didn't know which one to choose. Stock or something like Pedros Garage. Any thoughts?
Forgot about the coolant tank, glad I asked for input.
Will research the wiring, didn't know about that one.
Thanks all.
Old 12-20-2010, 08:22 AM   #6
If I read your question correctly, the shop wants to drop both the transmission and engine for an LN IMS retrofit. While the transmission must come out, the IMS is replaced with the engine still in the car. Doing otherwise is going to add a lot of unnecessary cost to the procedure.
2003 Boxster - Sold but not forgotten
timothy is offline   Reply With Quote
Old 12-20-2010, 03:16 PM   #7
Yes, this is what I have been told because it is a Tiptronic trans.
Old 12-20-2010, 04:14 PM   #8
Engine doesn't need to come out for any of that stuff. Get the LNE IMS retrofit rather than the Porsche IMS.
The shop will have to remove the chain tensioners, so you might want to replace those.
Mike_Yi is offline   Reply With Quote
Old 12-20-2010, 04:48 PM   #9
Steve Tinker's Avatar
The chain tensioners don't have to be touched to install the IMS bearing.
But they do need to be locked into position before removing the old IMS assembly.
2001 MV Agusta F4.
Old 12-21-2010, 02:39 AM   #10
Yes, I was going to do the LNE IMS kit as that seems to be the best choice.
Old 12-22-2010, 07:47 AM   #11
I just followed the instructions that came with the LNE IMS retrofit, and they indicated removal of the chain tensioners. I was not willing to risk a chain jumping a tooth because they were under pressure.
