Old 12-18-2010, 02:27 PM   #1
Courtesy/Step Light
Anyone know how to replace the courtesy/step light bulb in the door of a 97 Boxster?
I don't want to break something by doing it wrong.
BoxsTim is online now   Reply With Quote
Old 12-20-2010, 02:32 AM   #2
Spinnaker's Avatar
According to the Bentley manual:
"Using a plastic prying tool or a screwdriver with tape wrapped around tip, carefully pry out door courtesy light socket.
- Detach electrical connector, remove light bulb from socket and replace.
- Installation is reverse of removal. "
Get yourself a Bentley manual from Amazon for Christmas. It will be the best money you will ever spend on your Boxster and save you a ton on repair issues.
See you around on the roads of the Emerald City.
Old 12-20-2010, 08:49 AM   #3
Thanks for the info, Spinnaker.
Old 12-20-2010, 02:28 PM   #4
X2 on the Bentley manual
Very useful...gives u other ideas on what to look at for
preventative maintenance
Changing light was a breeze
U might want to change to led T10 bulb replacements
Brighter, whiter light
cheers
chris
Living one calculated risk @ a time
chris97boxster is offline   Reply With Quote
Old 02-27-2011, 11:38 AM   #5
Courtesy/Step Light on 2008
is the method the same on a 2008? i read this post and gently tried to pop it out but i didn't want to "get a bigger hammer". if it is, pry on an end or top of lens.
thanks, dan
TWODAN is offline   Reply With Quote
