Old 12-08-2010, 12:44 PM   #1
Ipod aux cable for CDR220?
Hi guys,
I wanted to know which cable you would recommend for me to connect an ipod/iphone to my CDR220 radio unit. Also, I wanted to know if they came out with a cable that would work with an iPhone 4? And last question, how hard is it to set up the cable? I'm guessing you have to plug in the cable behind the main unit, so how do you bring the cable back out? I hope you get what I'm asking in my last question!
Thanks in advance for your help!
knicksplayer is offline   Reply With Quote
Old 12-08-2010, 12:52 PM   #2
Johnny Danger's Avatar
You should check out this recent thread . And don't make the same mistake that I did !
ipod cable ?
Old 12-08-2010, 03:33 PM   #3
Go here: http://www.discountcarstereo.com/detail.aspx?ID=1467
They have an external audio input cable that connects to the rear of the CDR-220 along with three options for the player end connector (ipod/iphone, aux, or RCA jacks).
Installation instructions are on their site.
Please note that you will lose use of the factory CD changer (this is where the external audio cable plugs in).
Old 12-09-2010, 12:49 AM   #4
I have a cable from iWireP which I don't need. It works great with older iPods, but will only charge (not play) iPhones.
PM me if you are interested.
http://i1215.photobucket.com/albums/...dall/Car-1.jpg
2001 S Speed Yellow, matching interior, German Plates!!
Iflylow is offline   Reply With Quote
Old 12-09-2010, 09:08 AM   #5
pk2
For reference- http://hackaday.com/2010/06/16/using-ipod-docks-with-droid-via-an-adapter/ -
Not exactly what you want but shows ipod pin assignments PLUS shows how to work around the newer Ipod/ dock crippling feature.
You'll need a soldiering iron.
Regards, PK
http://img87.imageshack.us/img87/163...58x6ir4.th.jpg
99 Supercharged 2.5L
pk2 is offline   Reply With Quote
Old 12-14-2010, 10:06 AM   #6
Just get the cable from http://www.discountcarstereo.com/detail.aspx?ID=1467 and do the install yourself in 30 mins.
No soldering required. Just remove the radio (you'll have to get the radio removal keys online $5) and plug the cable into the open connector for the CD changer on the rear of the radio. Then attach the power wire on the cable to the power antenna wire using the included clip using a pair of pliers.
Then route the cable down the back of the center console and either drilll a small hole in one of the center shelves or keep going to the ashtray area and exit there. Just depends on where you want the cable.
Re-install radio. Select AUX in (how to do this is part of the instructions) and your're up and running.
Full installation instructions are included with the cable. If you need more help, full instructions with pics can be found online at the Pelican Parts site.
Old 12-14-2010, 01:53 PM   #7
Perfectlap's Avatar
be careful in pulling on the extension cord to route it back towards the front of the dash. I yanked too aggresively and the wires snapped right out of their little sockets. I had to pull the radio back out and pull a MacGyver without any tools to crimp the copper wire back together with some electrical tape as a temporary fix.
A $30 error as I had to order a new Ipod/aux jack from Becker here in NJ.
Also, when you use the hooks, you have to remove them before you push the radio all the way back in. There are little tabs on the side near where the removal keys are inserted that have to be depressed inwards to allow the keys to release.
BORN: March 2000 - FINLAND
