11-18-2010, 11:58 AM
winter motor oil
what is the best motor oil for cold ass winter New England driving ?
11-18-2010, 01:32 PM
Porsche recommended oil viscosity grade 5W40 for use in Scandinavia and Russia. I'm sure their winter temperatures would make a New England winter feel positively balmy......
A lot of people seem to be using Castrol Syntec - I use Shell Helix Ultra but I don't know if you can get that oil your side of the pond.
2001 MV Agusta F4.
11-18-2010, 03:05 PM
my owners manual says for synthetic below 50F use 10w-40 , 10w-30 or 5w-30 but after searching around this forum it seems like no uses those blends . the one thing i do know is that it will be Castrol syntec.
11-18-2010, 03:07 PM
ohh yeah and it does get that cold here !
11-18-2010, 04:36 PM
Approved Oils
Comments and link to a recent list from Porsche
11-20-2010, 08:54 AM
I have a '98 with 127k miles on it. It is running realy well. I have some questions for the forum.
I use M-1 10-30. My son is telling me to use 10-40.
Does 10-30 / 10-40 realy matter ? Which is best ? Is there something better ?
I've noticed many manufacutures going away from M-1 and now endorcing Castrol.
Why ?
Since it is a '98, I have considered using my motocycle oil since that has older style ratings.
Any thoughts ?
11-20-2010, 09:03 AM
Yes, the XW-40 weight does matter; XW-30 is too thin for the M96 engine once it is warmed up. Considering your location, something like Castrol Syntec 5W-40 would be a good choice..........
The reason Mobil 1 has fallen from grace is that it has been reformulated into a poor performing shadow of what it once was.
11-21-2010, 07:59 AM
would 10w-30 be ok for winter usage ?
11-21-2010, 10:56 AM
No; the M96 needs 40 weight on the high side, summer or winter...........30 weight on the high side is not enough.
Look for Castrol Syntec 5W-40 or 10W-40 (my preference).............
11-21-2010, 03:43 PM
I just happened to be reading page 168
Engine Oil Recommendation in my 986 owner's manual yesterday.
I was amazed to see that 10W30 is actually listed in colder (Below 50F/10C) environments. And then contradicted in bold with a "10W40" or higher statement.
I wouldn't and don't use ..W30 but I wanted to interject this little bit of Porsche's contradictory view into the discussion.
You ought to see the viscosity Honda recommends/uses!
11-21-2010, 05:42 PM
Now that i spent a little time trying to get a better understanding of what the oil numbers really mean , i guess that 5w-40 would be the oil to use year round . the thin 5w for cold start and the thick 40 for normal operating temps. the only thing i question is in january the temps here can stay down below freezing for some time. In those temps does the oil really make it to the "normal" operating temp ?
11-22-2010, 12:15 AM
The oil gets to its optimum working (hot) temperature only after about 5-6 miles of driving under normal conditions. The overall oil temperature is controlled (up to a point) by the coolant temperature via the oil / water heat exchanger mounted on top of the crankcase.
One way of causing oil contamination is to drive short distances in cold, humid climates at low temps - this causes high water & fuel contamination to the oil.
2001 MV Agusta F4.
11-22-2010, 08:59 PM
The dealership put in 0W40 Mobil 1 when they changed my oil. If I understand it all, wouldn't 10W40 be the best choice for Houston?
11-23-2010, 03:58 AM
Any name brand 0-40 or 5-40 synthetic should do the trick.
Rich Belloff
11-23-2010, 07:07 AM
If you do your research, you'll find knowledgable people say to to stay away from Mobil1
