Old 11-16-2010, 05:02 PM   #1
muffler fitment
hey all, i believe there is a rattling noise in my 02 exhaust system. however, i can't seem to locate the exact location. i am just going to start to replace parts, starting at the muffler. does anyone know what years will fit onto 02? i have an opportunity to put a 98 muffler on and believe it will fit. however, i also have the opportunity to put on 05 s-muffler for same price. but i was told by local dealer this will not fit. is that true? any help would be appreciated. or anyone have a muffler, please let me know. thanks.
-Tuan
tuanle16@juno.com
tuanle16 is offline   Reply With Quote
Old 11-17-2010, 03:16 AM   #2
If you look at the way the after market manufacturers break down fitment, I'd say it's unlikely the 98 muffler would fit. If you are doing this merely to solve a rattle, why not check all the heat shields surrounding the cats first?
eightsandaces is offline   Reply With Quote
Old 11-17-2010, 04:09 AM   #3
thanks. i have checked everything else. ie..all heat shields and used a mallet and knocked around. can't seem to reproduce at idle, but only at 2-3k rpms. very frustrating.
but thanks for your thoughts.
i was told by the local dealer that 98-2004 were the same muffler.
-Tuan
tuanle16@juno.com
Old 11-17-2010, 07:16 AM   #4
check the connecting pipes entering the ends of the muffler. Mine rattled even though the clamps were tight.
00'Speed Yellow S
bluelagoon is offline   Reply With Quote
Old 11-17-2010, 08:35 AM   #5
Bruce Wayne's Avatar
my heat shields have been rattling since i took ownership of the car 3 years ago.. been under it so many times tapping about trying to find where exactly the rattle at low revs was coming from..
.. today i was at lakeside engineering having a coolant flush and s/steel brake lines put in and Max made same comment about the exhaust rattle at which point i mentioned ive been trying find the rattle..
sensors he said, grabbed a spanner.. 10 seconds later, all done.. exhaust is rattle free !
go figure !
986 x2 6sp
2x Range Rover Vogue 4.6
2004 MX5 Sport 6speed Strato Blue (wifelet)
2x Range Rover Classic & CSK
Bruce Wayne is offline   Reply With Quote
Old 11-17-2010, 02:08 PM   #6
The Radium King's Avatar
fyi, there is i fellow on this board (username 'Paul') who has a cayman (ie 987) exhaust sytem on his 986 - headers, mid pipes, exhaust. apparently a bolt-on application; the only fabrication required was the extension of 02 sensors. if you can get a 987 exhasut on your car i say go for it, as concensus seems to be that the 987 has a better 'sound' that 986.
