Old 11-13-2010, 12:10 AM   #1
buzzing engine noise. Help!
Hello, I started to hear a buzzing sound, I think was the belt tensioner or any accesory (water pump, alternator,..) bearing of the belt, I checked all of them and the belt and is OK. I haven't discovered where side the noise come, I only hear inside the engine.
What do you think is?
you can see a video I've recorded:
http://www.youtube.com/watch?v=p85bzy-3Mjg
heiwaz is offline   Reply With Quote
Old 11-13-2010, 03:04 AM   #2
remove the belt then start the motor for a short time while listening. if noise is gone shut motor off and feel all the pulleys for play
extanker is offline   Reply With Quote
Old 11-13-2010, 03:08 AM   #3
^--- what he said. Definitely sounds like an accessory -- my bet is alt. Don't run the engine for more than 30 sec without the belt... But you probably knew that already.
-- John
'00 Boxster S
'86 911 Carrera Coupe (Sold)
Lucky is offline   Reply With Quote
Old 11-13-2010, 04:47 AM   #4
I started the motor without the belt, but the noise still go on.
Old 11-13-2010, 04:52 AM   #5
try unscrewing oil fill cap while engine is making noise
Old 11-13-2010, 06:04 AM   #6
Why should I try this? if I remove the oil fill cap, the noise dissapear and why?
Unfortunately at the moment is impossible to try this, because I have doing the IMS upgrade, and the gear box and clutch is out of the engine. But I want to take advantage of this dissasembly to give a solution to this noise.
Old 11-13-2010, 07:36 AM   #7
some of te sounds people report from the AOS going bad are ...well a little odd
Old 11-13-2010, 08:54 AM   #8
so, if the problem came from de AOS when I try to unscrew oil fill cap, what happend with it? it's hard to remove or what? thanks.
Old 11-13-2010, 09:24 AM   #9
have you talked this noise over with the people that are working on your motor ?
Old 11-13-2010, 09:55 AM   #10
No, I'm doing by myself. I've got mechanical title
I'will check the AOS.
Old 11-14-2010, 12:27 PM   #11
J Tinsby's Avatar
Do a search ....
Search using the word AOS then find the post called " Is my AOS going?" Scroll down and read the posting by 944boy. His post sounds very much like what you describe.
Good luck,
J T
Sorry I don't know how to copy the link to someone else's posting for you.
J Tinsby is offline   Reply With Quote
Old 11-14-2010, 02:26 PM   #12
Good luck,
J T
This sound he described is a vacuum sound, it's different that mine.
Old 11-15-2010, 05:09 AM   #13
jcb986's Avatar
When a AOS goes bad or starts to go bad you may have a different warning sounds. The most common is smoke coming out of the engine when running. Mine made a whistle like screetch when the engine warmed up. The vacuum that is being pulled can suck air around the crankshaft seal. So, if you cannot remove the oil filler cap when the engine is running then the AOS is going bad. Was this noise there before you started doing the engine maintenance, if so, then you did not cause the problem. Not sure if you are suppose to run a flat 6 with the flywheel off.
Old Hippie Young Heart
Old 11-15-2010, 05:39 AM   #14
i wanna see him start it with the flywheel off...does yours have a pull start
Old 11-15-2010, 05:50 AM   #15
this noise appeared, 2 das before I start to do the maintenance.
Is possible this noise come from the start engine?
Old 11-15-2010, 03:07 PM   #16
jcb986's Avatar
Get a stethoscope from the auto store, remove the belt and listen for the sound around the crankshaft seal and listen to the timing chains. How many miles the Box.
Old 11-16-2010, 08:35 AM   #17
it has got around 90000 miles.
Now I'm changin the IMS bearing, so the chain are loose, how can I check it? should I check the chain tensioner, too?
Old 11-16-2010, 08:42 AM   #18
pull the oil sump and cut open your oil filter....tell us what colors you find and the size of the stuff
Old 11-16-2010, 09:08 AM   #19
sorry I don't undestand very well you what you want to tell me. can you explain me? do you want to open de oil filter to see what color is? I emptied the oil, but I've got the old oil keep in a bottle.
Sorry but my english sometimes is not perfect. thanks.
Old 11-16-2010, 09:15 AM   #20
do you know anyone in your area that knows engines made by PO that can help you ?
