Old 09-15-2010, 07:32 PM   #1
Newbie. Clutch issue
I purchased a 2001 boxster base 2.7 liter, and seems like every couple weeks the clutch engagement point goes higher and higher, I don't know if the clutch is going bad or the system needs to get bled. Any ideas?
Also if a new clutch is needed where can I get one and what kind?
Art902087 is offline   Reply With Quote
Old 09-15-2010, 08:02 PM   #2
Try bleeding it first, which is cheap and easy. Maybe your clutch master cylinder is going bad?
gschotland is offline   Reply With Quote
Old 09-16-2010, 03:27 AM   #3
If the bleed doesn't fix it and it's not a slave cylinder or some other hydraulic leak make sure to stay on top of it, allowing the dual mass flywheel to sustain damage will increase the repair costs dramatically.
eightsandaces is offline   Reply With Quote
