Old 09-12-2010, 05:37 PM   #1
noise when powering thru corner
After about 3 runs on a autox course I started to get a grinding noise from
the rear when ever I apply power thru a corner
does anyone nave a clue as to what may cause this symptom?
yamatodog is offline   Reply With Quote
Old 09-12-2010, 05:54 PM   #2
jcb986's Avatar
My guess is that you may have a bad motor mount or a CV going bad.
Old Hippie Young Heart
Old 09-12-2010, 06:17 PM   #3
the noise sounds like the water pump grinding on something,I am thinking about driving the car with the front axcess cover removed.
Old 09-12-2010, 06:17 PM   #4
Thumper's Avatar
Could also be a wheel bearing going south on you.
Thumper is offline   Reply With Quote
Old 09-12-2010, 06:32 PM   #5
I'll get back to all of you once I do some digging
Old 09-12-2010, 06:42 PM   #6
07 Carrera S Cab
Boxtaboy's Avatar
I had a grinding noise/vibration when I powered thru right hand turns. Turned out to be a worn motor mount. It failed at 60k miles. New mount fixed the issue.
