Old 09-08-2010, 05:29 PM   #1
Look what I found laying on top of my engine!
The engine in my '02 S blew up at Road Atlanta last month. I finally got in the garage and started taking the engine out and look what I found on top of the engine case.
This was a re-manufactured engine that was replaced by Porsche for the previous owner of my car. It only had 60K miles! Here's the hole it left.
Many questions! In watching the video of the engine blowing up, I didn't think it had grenaded to this level. A bit of clatter, but no big boom. What causes a rod to jump ship like this? Shouldn't a Porsche built engine last more than 60K? What must I do to insure that the next engine doesn't do the same thing? Obviously a rebuild is out of the question. Do I go back with a 3.2 or use the opportunity to upgrade to a 3.4? Can I do a 3.4 myself in the garage? Is a 3.6 possible?
Here's a link to the video.
http://www.youtube.com/watch?v=lPBjaIOwERU
Byron in Atlanta
Byron in Atlanta is offline   Reply With Quote
Old 09-08-2010, 05:45 PM   #2
07 Carrera S Cab
Boxtaboy's Avatar
Doesn't look like JB Weld will fix that.
Options: http://www.pelicanparts.com/techarticles/Boxster_Tech/11-ENGINE-911_Engine_Swap/11-ENGINE-911_Engine_Swap.htm
Old 09-08-2010, 06:03 PM   #3
jcb986's Avatar
That piece of rod looks pretty scorched. Usually a sign of oil problem. Maybe you lost oil pressure and spun it...sizzed up and snapped.
Old Hippie Young Heart
jcb986 is offline   Reply With Quote
Old 09-09-2010, 02:51 AM   #4
Yeah, when I blew up my Formula Ford engine, I was surprised at how little drama there was. No big Nascar ball-of-flames, just one loud thump, like the transmission jumped out of gear, then silence.......... It ends up my crankshaft broke in 3 places, shooting parts out the block and pan!
As far as yours, rod bolt failure?
Steve
Old 09-09-2010, 03:07 AM   #5
Strange odds, now that frame is set for engine number three..
eightsandaces is offline   Reply With Quote
Old 09-09-2010, 08:22 AM   #6
Sorry to hear that
However, that is why I have upgraded rods and ARP bolts in the 3.8 I built that's in my car. In your case, I would suspect an oiling issue, which is a common problem of all the M96 series engines when put on the track.
Obviously what you have left isn't going to be rebuildable, but on your next motor (whichever route you go with), I'd strongly recommend, at the very least, the 996 X51 pan (which is MUCH better baffled), while the real solution is an accusump.
Boxster S
Old 09-09-2010, 10:29 AM   #7
Lil bastard's Avatar
Not exactly a testamonial for the quasi dry-sump engine.
I wonder who had the last say at that meeting - the engineers or the accountants?
Too bad your in-car cam didn't show the tach through the run.
Do the 3.6, you'll be happy you did!
But be sure to add the deep oil sump w/ baffles!
Cheers!
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
Old 09-09-2010, 10:50 AM   #8
edevlin's Avatar
That cannt be good.......
Ed
My Car Webpage
2000 2.7L Boxster 102K; TTP intake, headers, high-flow cats; Dansk high-flow muffler; Autothority ECU chip; TechnoTorque 2; Bilstein coilovers; Racing Dynamics strut brace; stress-bar suspension kit; Aasco lightweight flywheel, B&M short shiftkit; 18" wheels; spare tire delete; OEM GT3 seats; JL audio speakers and subwoofer; Alpine PDX-5/PDX-2 amps; Kenwood DNX8120 CD/DVD/Nav; litronics, deambered
edevlin is offline   Reply With Quote
Old 09-09-2010, 11:52 AM   #9
Porscheectomy
You have to look at the bearings, the crank, the rings, and the cylinder to know if it's an oiling issue. It could also be fatigue of the less than stout rods and/or crankshaft.
