Old 08-25-2010, 11:32 AM   #1
Blinkers/Hazard doesnt work. No air being blown either.?.?
I changed my battery after a complete drain and after the new battery was installed my blinkers no longer work. They dont do anything when the switch is engaged. The hazards do nothing as well when the switch is pushed.
Another thing is my ac and heater no longer blows air. It seems to cool and slightly changes the rpm's when turned on but no air comes out.
I am thinking it is relays but I dont know for sure nor do I know where they are.
Anyone have any idea's?
MJ
mrtorino is offline   Reply With Quote
Old 08-25-2010, 11:46 AM   #2
check the basics.....are all the wires hooked back up to the batt ? check the fuses
extanker is offline   Reply With Quote
Old 08-25-2010, 11:58 AM   #3
betcha you don't get a 'clunk' when removing the key from the ignition either?
How'd the battery die?
Suspect common ignition switch failure. $8 (if bought online from ************************************************************) DIY R&R with directions here courtesy of Mike Focke's Boxster page
