Old 08-24-2010, 09:06 AM   #2
Johnny Danger's Avatar
Originally Posted by The Radium King
hiya; my research tells me these wheels will fit my 2000 986S, but need confirmation from the experts prior to the pulling of the trigger:
Front Wheel Details:
p/n: 993.362.136.00
width: 8.0"
Offset (mm): 52mm
5x130 bolt pattern
Rear Wheel Details:
p/n: 993.362.140.00
width: 10.0"
Offset (mm): 40mm
5x130 bolt pattern
thanks in advance.
As long as the center bore for a 993 is the same as a 986 (71.6), the fitment of those wheels will definitely work with your vehicle. Although,, a lower offset for the fronts would be more desirable, you won't have any issues as far as clearance is concerned. Besides, you can always use spacers to achieve a more aggressive stance. The rears @ +40 et will make for a very nice fit. Good luck !
