Old 08-18-2010, 08:06 AM   #1
Cool Boxster with Cayenne Suspension & Big Brakes Upgrade Swap Help!
Working on my 99 Boxster and I would like to know any available upgrade swaps for suspensions and big brakes. Can the Cayenne brakes/ suspension parts work?
Any suggestions? Thanks
alipendier is offline   Reply With Quote
Old 08-20-2010, 07:20 AM   #2
Doc
How much power is your engine putting out, to necessitate these changes?
Fluellen is offline   Reply With Quote
Old 08-20-2010, 07:25 AM   #3
Seems like Boxster S big reds would be an easier conversion, I'd be surprised if Cayenne rotors fit the Boxster. I don't understand the track change either, what is your ultimate goal?
Old 08-20-2010, 04:21 PM   #4
Cool
I anticipate about 420 - 450 HP, thanks for all the replies...
Old 08-20-2010, 06:42 PM   #5
Doc
Have you considered 996TT brakes?
Old 08-21-2010, 04:48 AM   #6
Cool
Not yet but I can research it now, are they direct bolt-ons? Thanks for your input
Old 08-21-2010, 07:29 AM   #7
Garrera GT Kit?
I just stumbled on this thread. I did some looking around on the net. Are you turning you Boxster into a Carrera GT look alike? That would explain putting in a V12....
www.kitanautobodyexperience.com/stretchyourboxster.htm
backman_z is offline   Reply With Quote
Old 08-20-2010, 08:19 AM   #8
Yeah: Forget about it. First, you already have all the brakes you will ever need; and as far as moving the wheels out 4 inches on each side, besides looking ridiculous, you will be encountering all kinds of interference and evil suspension loading issues...........
Rather than “bling” spend your money on some DE driving lessons……..
Old 08-20-2010, 01:06 PM   #9
Topless's Avatar
The sure thing front brake deal is to simply bolt on Box S rotors and calipers. It is a direct replacement and will improve your front brake heat capacity. Stopping distance is more a matter of weight and tire grip. No shortage of clamping power with stock Boxster brakes.
The rears are tougher. If you want Cayenne rotors on the rear and a wide track, what about using the whole Cayenne, rotor/caliper/hub/axle/ assy and cutting to fit your desired track width? You may need that heavier axle assy anyways due to the other "stuff" you've got going on with your car. I am afraid getting all the rear suspension geometry right with such an increase in track width is above my pay grade. Good luck and when you are finished, pics are mandatory
For those who don't remember, Ali is the guy who is doing a cut and stretch on a Boxster, dropping in a monster high displacement motor and then fitting some mystery (Bugatti???) kit car body around it. I am not this projects #1 fan but I appreciate his determination and hey... whatever floats your boat. The results are guaranteed to be interesting to say the least.
Old 08-20-2010, 01:28 PM   #10
Now I remember, the "if you have enough welding rod and duct tape, anything is possible" project...............
