Old 08-11-2010, 04:16 PM   #1
Peer's Avatar
Check engine light...
I know I should've asked this earlier -- a couple of months ago my 'check engine' light came on. Since I was kind of "occupied" at the time, I didn't do anything about it... and then, a few days later, it went away. Any suggestions what happened there, and/or if there's anything I should do about it now?
-- peer
Peer is offline   Reply With Quote
Old 08-11-2010, 04:21 PM   #2
As long as it was not a flashing CEL, probably no big deal. The code may be stored (even though the CEL is gone), so you may be able to still get a read out if you can get it hooked up to a scanner (free at Auto Zone and similar places).
Old 08-11-2010, 04:25 PM   #3
Peer's Avatar
Thank you for quick reply. No, it wasn't flashing. Do you have any guess what it might have been?
-- peer
Old 08-11-2010, 05:19 PM   #4
jcb986's Avatar
I had one come up when I changed the plugs...didn't get the connection on tight. During a test drive, I got a little miss after a few miles and the check engine light came on. I knew the one that I was having a hard time getting snapped back into place and it did pop lose. Once I had it back on correctly the check engine light went off after several drives. The computer will automatically reset the cell after so many cycles...I believe it's 10. So your problem could have been a misfire or anything, but the problem went away and the cell was reset. Check and see if the code is still stored, this will point in the right direction.
Old Hippie Young Heart
Old 08-11-2010, 05:57 PM   #5
Peer's Avatar
Oh, by the way, I had the car smog checked (CA) after this episode, and it passed with flying colors.
-- peer
Old 08-12-2010, 06:20 AM   #6
-- peer
I was going to suggest that you get your car inspected while it is not throwing codes, so then you don't have to worry about the CEL for a whole inspection period. But it sounds like you might have done that by getting the CA smog test. Here in NY the emissions test is part of the NYS inspection process. I'm guessing CA is more stringent [CA people often complain about it ].
My CEL was off for about 9 months, I kept putting off the inspection. Now I have 1 month left, and my CEL came on yesterday ... :ah:
Gougoushu is offline   Reply With Quote
Old 08-12-2010, 05:26 AM   #7
Yeah, those little guys can be hard to get snapped back on tight, can't they? I had a CEL indicating misfire, cylinder 1, so I switched the coil packs of cylinder 1 & 2 to see if the problem moved to cylinder 2. Didn't get one of them snapped back on tight...and was running on 5 cylinders briefly. That tripped a flashing CEL.
Old 08-11-2010, 06:46 PM   #8
-- peer
Honestly, there are hundreds of potential codes that it could have been, and quite a lot of the codes have multiple potential causes.
The only true way to know what caused your code would be to pull the code using a scan tool, or something similar.
BC.
Its not how fast you go, or how expensive your toys are.
Its all about how big your smile is at the end of the day that truly matters.
'98 Silver Boxster, '08 Ducati 848, '89 Honda Hawk GT, '89 Honda Pacific Coast
Bladecutter is offline   Reply With Quote
