Old 08-11-2010, 05:51 AM   #1
Wind Deflector Clip
So, like an idiot, I broke the wind deflector passenger side clip that attaches to the plexiglass...(pressed too hard, snapped in my hand - DOH!)
I ordered a new one from Suncoast (very helpful by the way). They said you just "pop the old one off, and pop the new one on"...
Is it really that easy? Anyone ever done it? Do I just "pop" it off with a flathead, and pop the new one in? I'd hate to have to replace the whole wind deflector cause I'm dumb...and I don't want to ruin the rubber seal around the deflector...
Thanks!
Rick
2002 Boxster S
Rfromet is offline   Reply With Quote
Old 08-11-2010, 12:51 PM   #2
Yes, they come off fairly easily. Practice with the one you broke.
I didn't realize you could buy just the clip - I broke mine and ended up using a special superglue kit (comes with a marker that prepares plastic, Loctite brand I think), after a couple other types of glues failed.
-james
'01 Boxster S, 51k miles
'05 Mazda 6 Grand Touring Wagon
yimmy149 is offline   Reply With Quote
Old 08-12-2010, 12:37 PM   #3
ChrisZang's Avatar
welcome to the club I seem to be a bit brutal and had to replace already 3
It's totally simple to do
Old 05-16-2012, 08:05 AM   #4
First Post....
Just purchased 2000 Boxster and I also have broken clips on wind deflector. I found this part on Suncoast - Code: 986WSCLIP. Is this the correct part number? Also, how hard is it to replace this? Do I twist off or pull straight out?
Tony
amarcozzi is offline   Reply With Quote
Old 05-16-2012, 08:13 AM   #5
SoK
I cracked mine, but it still locks in the wind deflector fine at 80+, so i havne't changed it. Tried taking the broken one out of the roll bar, though, and I couldn't get it. What's the trick? Seems like it's attached to a metal tab that slides into the roll bar, but it would not come out for me no matter how hard i pulled and moved it around.
2001 Seal Gray 5-Speed - 2007 Yamaha R6 - 2003 Honda Civic EX - 1999 Nissan Frontier XE - 2003 Coleman Utah
SoK is offline   Reply With Quote
