Old 09-25-2011, 10:05 AM   #181
Originally Posted by kcpaz View Post
No, the air-jack tubes are welded into the chassis itself.
Where and how do you make them work? Do you use an external compressor to inflate them? Do you use a race jack to lift the back before you inflate them, or are they strong enough to lift the car from the ground on their own with enough compressed air?
Why this bit is fascinating to me is beyond me considering everything else you've done, but I'd love to know.
Old 09-25-2011, 10:38 AM   #182
Opposed to Subie Burble
Overdrive's Avatar
Hey, I'm with you, Randall. If this was something that could be employed on a stock car, I'd go for it. Could allow you to do certain things underneath without having to fully jack/lift the car...and it'd be kinda cool to show off, heheh...
:dance:
-O/D
IMSR + RMS
Robbins glass window top
Old 09-25-2011, 04:57 PM   #183
Spinnaker's Avatar
:dance:
Dear Overdrive,
If you ever do anything under a car with only air jacks holding it up, I will personally come to Conn. and kick your ass and maybe bring flowers to your funeral. I've never been to the East Coast, don't give me a reason to do it.
Old 09-25-2011, 05:19 PM   #184
Overdrive's Avatar
Originally Posted by Spinnaker View Post
Dear Overdrive,
:dance::dance:
You could come give me a hand with the safety stands...would that be a good reason?
It's good to know people care, Spinnaker. Alas, just jokes...but it would be kinda cool to have air jacks on the car...no worries about flat spots over the winter.
-O/D
IMSR + RMS
Old 09-25-2011, 05:36 PM   #185
Porscheectomy
Wiring is DONE! Other than the ABS system, the chassis harness was built from scratch. The engine management is stock from the 2007 WRX donor and fit in the stock Boxster location using all stock mounting points. We were even able to use the stock Porsche ECU mounting studs with the stock Subaru ECU and relays. Everything powers up and the engine cranks. Still need to plumb the oil system, fuel system, and cooling system, but then we should be able to fire it up and get it on the dyno for some tuning.
Rear trunk
Accu Sump
You need to replace the shift mechanism with a 997 unit.
Old 09-25-2011, 06:52 PM   #186
When I upgrade the shifter, it will be to a CMS unit with custom cables.
kcpaz is offline   Reply With Quote
Old 09-25-2011, 07:13 PM   #187
Porscheectomy
Even better.
Old 09-26-2011, 12:58 PM   #188
clicky
Old 09-26-2011, 01:25 PM   #189
Overdrive's Avatar
Someone made a kinda good point about the price that can go along with a system like this in a forum thread link that popped up on kcpaz's search results above:
"for that price you can buy a lift for your garage"...true, it'd sure make tire changes a lot faster, though.
How much does that system weight, kcpaz (ballpark)?
-O/D
IMSR + RMS
Old 10-14-2011, 06:24 PM   #190
Subaru Powered Boxster First Start-up - YouTube
Old 10-15-2011, 06:00 PM   #191
stcroixdrew's Avatar
wow!!! need i say more?!!!!
Drew Lyons
Red Hill, Pennsylvania
St. Croix, US Virgin Islands
1998 Arctic Silver Boxster
stcroixdrew is offline   Reply With Quote
Old 10-15-2011, 06:55 PM   #192
JAAY's Avatar
So when are you going to make a cradle, tranny adapter and clutch available for purchase????????
Old 10-15-2011, 08:32 PM   #193
Before the end of the year.
Old 10-16-2011, 05:09 AM   #194
JAAY's Avatar
Thank you! I may be first in line.
Old 10-16-2011, 07:44 AM   #195
J Tinsby's Avatar
What scares me the most is that one crash will destroy all your hard work and time invested. Everything you have shown us is top notch in every regard, just hate to think of it getting trashed by some boob on the track ....
Best of luck it's an impressive bit of kit.
J T
"Never force it.... get a BIGGER hammer!"
J Tinsby is offline   Reply With Quote
Old 11-01-2011, 01:21 PM   #196
We are also using this car to test out a few non-conversion related products including a programmable brake light flasher module. With this module, we are able to set the brake lights to activate with an adjustable number of flashes prior to constant illumination, and adjust the flash frequency (faster flashing available with LED bulbs). This is something we are developing specifically for full size cars and is not just a retrofitted motorcycle flasher unit.
Race Car Brake Light Flasher - YouTube
Old 11-01-2011, 01:50 PM   #197
Overdrive's Avatar
Can we hear more non-limp mode engine running? Are things closer to being in proper running order for a legit running?
I had a Subie guy drooling at that first video, curious to see how it sounds all put together and ready to haul.
-O/D
IMSR + RMS
Old 11-01-2011, 01:55 PM   #198
I'll put up a video of the dyno tuning. Probably another week or so.
Old 11-12-2011, 11:22 AM   #199
Finally, all of the plumbing is finished, communication for the Racepak dash is finalized and programmed, and it's ready for a tune. More video coming soon...
Old 11-13-2011, 05:23 AM   #200
Brinkley's Avatar
I'm late to this build thread...but I have to reiterate what others have said, your fabrication skills, welding skills are phenomenal!!!!
As someone who built a boxster into a dedicated race-car with a 3.6L 996 motor I can't get over your thoughtfulness in locating every system so that it is serviceable. The detail work of the plumbing is fantastic.
You showed a close up of two stainless tanks, what are they? Engine Oil and Engine Coolant?
Just fantastic!
Brinkley is offline   Reply With Quote
