Old 08-03-2010, 07:08 AM   #2
Ignition switch
or a sensor that determines if the clutch is in, the gear box is in neutral or the steering wheel is locked? I've had the same problems and it was a gear box interlock mechanism. I wiggle the steering wheel and the gear lever and the next time I try it starts. Took it into the dealer and they sprayed something on it and gave it back no charge! Contact cleaner? Much better now.
