Old 07-03-2010, 03:39 PM   #1
Porsche actually did have a printed "OBD II Diagnostics" manual for each model series (986, 996, etc.) that gave you a diagnostic decision tree for each code; but those are no longer in print. Pelican used to offer a reprint of the one for 986's thru 2004, but I do not know if they still do, you'd have to check with them......
Old 07-03-2010, 03:52 PM   #2
This one? Worth the $35 I suppose?
Old 07-04-2010, 07:51 AM   #3
It is good, but not perfect; it has most of the possible codes, but lacks the "TSB" updates the OEM version had until they stopped printing them. It is also only useful up to 2004 models (and not even all of them), so it does not cover the later DME's. Unfortuantely, it is also the only source currently available for sale.............
Old 07-10-2010, 11:32 AM   #4
Track rat
Topless's Avatar
OBDII diagnostic info is free to members at renntech.org. No need to buy the book IMHO. Get the codes, search diagnostics, search forums for causes and cures... works every time and did I mention it is totally free.
Old 07-10-2010, 01:40 PM   #5
Good to know...Thanks!
Old 07-11-2010, 07:00 AM   #6
The info on RennTech is simple broad context data: "P0101 Mass Air Flow Sensor - Signal Implausible "; the OEM OBD II diagnostics book would tell you exactly what to test (which pin or terminal), what to test it for (e.g.: voltage, continuity, etc) in order to determine what was wrong with the MAF and if it could be saved............much more useful when trying to repair a car.
