Old 04-22-2005, 02:52 PM   #1
Brucelee's Avatar
Talking
Originally Posted by Richard Truss
where is that, exactly?
Under the front hood, near the cabin filter, left of the battery.
Surprised it still works under there but nice to know it does!
Old 01-27-2017, 06:30 PM   #2
Lew
So Blessed!
Lew's Avatar
I did not want to start a new topic/Saving space on the Server
This picture is the back of my CDR23 Radio and shows a 10 amp fuse. I am thinking about using a fuse tap on this fuse to get 12 volts that will supply a Stratus 7 Portable Satelite Radio. I hope to do a custom install in the opening once I remove the CD Caddy. I plan on using a blank face plate that will surround the radio. I could tap into the Brown wire which is ground, and the joined RED/BLK wire which is Positive, but a single tap on the 10 amp fuse would be better than two.
Artic Silver Boxster S - Black Leather - Black Top - Convience Plus Package
Lew is offline   Reply With Quote
Old 01-28-2017, 03:35 AM   #3
Lew
So Blessed!
Lew's Avatar
Don't know what I was thinking about, that 12 volt tap would not be a switched tap.
However it would have been the shortest run with my cable. Anyone make a 12 volt switched tap?
Old 01-28-2017, 07:26 AM   #4
Here is an interesting way to mount the antenna
https://cai-store.com/collections/996-986-porsche-audio-upgrades/products/premium-satellite-antenna-mount-for-911-cayman-boxster
Old 01-28-2017, 07:44 AM   #5
Chuck W.'s Avatar
When I had my 993 I did successfully tap into the radio plug wires. I believe it was on plug C. Below may help you;
1995 Porsche C4 Cab
Old 01-28-2017, 09:03 AM   #6
Lew
So Blessed!
Lew's Avatar
Thanks Achillies for the site on mounting the Antenna, but I have already mounted it. Take a look at the picture where you can see how I planned on installing. I was able to place the small Antenna near the corner of the windshield on the drivers side, and route the wiring under the trim and tuck it under the rubber door seal. It worked out great routing the wire under the lower part of the dash and over to the opening where the CD caddy is located. Since I don't use the CD Caddie I decided to remove it. I might add I am holding the Antenna in place with a quarter size piece of velcro. I plan on cutting a piece of plexi glass I have that will face off the Caddy opening. The Radio will be attached to the Plexi Glass with screws that came with the Radio. Should work out great.....
