Old 06-28-2010, 02:50 PM   #1
Rain water leaking
A small amount of rain water is leaking from the bottom center of the plastic rear window.
Before I do something stupid and regrettable on my own, can you guys recommend what has been done that worked?
Thanks in advance,
mikehkang is offline   Reply With Quote
Old 06-29-2010, 10:09 AM   #2
jcb986's Avatar
If it's leaking into the foam rubber tray and draining out...not much to worry about. Sealing and patching is usually a temp. fix. You need to the plastic replaced if the top is in very good condition. A good shop in is usually around $450 for the repair. be sure that they have done Boxsters before.
Old Hippie Young Heart
Old 06-29-2010, 10:38 AM   #3
Thanks for the reply JCB.
I am afraid the leak leaves the carpet/engine insulation wet. A heavy passing shower left a half-dollar size wet spot.
I will apply a small amount of clear silicone adhesive sealant.
