Old 06-20-2010, 09:20 AM   #1
The Radium King's Avatar
resonance tube
hello. i am in the process of 'learning' my recently acquired 2000 S. on a tour through my engine bay i noted that everything was really clean except there looked to be a slight accumulation of oil and black soot on my resonance tube, in and around the vacuum valve location. is this normal? thanks, trk.
Old 06-20-2010, 02:36 PM   #2
can you post a picture of it ?
extanker is offline   Reply With Quote
Old 06-21-2010, 09:57 PM   #3
i actually cleaned it all off, so nothing to see at this point ...
Old 06-22-2010, 06:47 AM   #4
ppbon's Avatar
It is kind of normal...
... because the tubes have mold seams that allow oil to leak out.
A small amount of oil coming from the Air/Oil separator is OK, but if it's excessive then the A/O Separator needs replacing.
Check your throttle body and the inside of the intake plenums for oil.
Happy Boxstering,
Pedro
Racecar spelled backwards is: Racecar!
ppbon is offline   Reply With Quote
Old 06-22-2010, 08:21 AM   #5
thanks pedro, my spidey senses were starting to send me the aos direction. no sign of it in the exhaust yet, but i'll give the aos and intake plumbing a look and see what i find. trk.
