Old 06-25-2010, 06:21 AM   #21
jim_hoyland's Avatar
Interesting information about the 5 classes, never knew that. What class would Swepco 306 be ?
And, how can one tell which class an oil belongs to from looking at the container ?
jim_hoyland is offline   Reply With Quote
Old 06-25-2010, 02:07 PM   #22
Originally Posted by sppmo
I think you should use whatever brand oil you prefer. I personally don't think there is much difference in any brand. It's like THD (total harmonic distortion) in stereo equipment. Sure you can measure it but you can't hear it under a certain threshold.
I've had cars where I have not changed the oil in 50,000 miles and have not had a problem. But i'm sure people would say I am nuts.
OK your nuts.
I do run the Castrol 10w40 in the Boxster. All my other cars run the oil called "On Sale".
My Porsche mechanic drives a Saturn.
'98 Artic Silver w/ Tip
vath2001 is offline   Reply With Quote
Old 06-26-2010, 01:59 PM   #23
Porsche has issued two TSBs on oils. One lists a whole bunch of oils by the country to be used in. The other specifies SAE 0W-40, 5W-40 and one or two 5W-50s.
Make sure API SL minimum, and ACEA A3/B3.
I used Motul 300V 5W-40 last year, a Group 5, maybe 4 oil that is very expensive. I'm going to Castrol Syntec 5W-40 this year to save some money.
OBTW LNE also makes a magnetic drain plug that I will be checking with upcoming annual change.
Mike
04 Boxster S - Basalt/Savanna, 6sp, Carrera lites, hardtop
70 914-6 - Black over tan, original/stock
PCA since 1970
70Sixter is offline   Reply With Quote
