Old 06-15-2010, 05:51 PM   #1
Lacrosse1
Brakes
I've got 104,000 on my 2002 Boxter, and was informed that the brakes will need to be replaced - the light has not gone on yet. What is the usual cost of this maintenance?
Thank you!
lacrosse1 is offline   Reply With Quote
Old 06-15-2010, 06:41 PM   #2
husker boxster's Avatar
Between $150-$200 for a set of pads (depending on which brand you purchase) and 2.5 hrs of fun. You'll spend more time removing and replacing each wheel than changing the pad.
There are plenty of threads on how to do it. Pads are easy to remove on a Porsche and you need relatively few tools for the job. Good DIY job for novices. However, brakes are a vital component of your vehicle. Be sure to carefully test them before going on a bonzai run.
1989 928 S4 5 spd - black
Old 06-16-2010, 03:58 AM   #3
jcb986's Avatar
You can get 4 new Balo rotors and Mintex pads for about $275.00. Also, do a brake fluid flush.
I noticed you are in Ohio...here's a check list.
* Brake Rotors - Front and Rear
* Brake Pads - Front and Rear
* Brake Pad Wear Sensors - Front and Rear
* Brake Pad Retainers - Front and Rear
* Brake Pad Vibration Dampers
* Brake Rotor Retaining Screws
* Ate Super Blue brake fluid (2 liters)
* Wurth brake cleaner (2 cans)
* Lubro-Moly anti-seize compound
Porsche dealers only replace the caliper bolts if needed...use some blue locktight and some anti-sieze paste when replacing them.
Old Hippie Young Heart
Old 06-16-2010, 05:48 PM   #4
dallison's Avatar
this costs about the same as most normal cars
dallison is offline   Reply With Quote
