Old 06-08-2010, 04:41 PM   #1
Symptoms of AOS?
What are the symtoms for a bad AOS? Does it fail over time or does it just fail immediately?
thanks
silverboxter is offline   Reply With Quote
Old 06-08-2010, 05:17 PM   #2
my car's AOS came on light turning a light switch. maybe there were tell tail sign but I was not aware of it.
sharp right turn on a freeway on ramp started a white smoke like crop duster.
50+ feet high with equal width.
thought the head gasket blew.
01 boxster 5 speed (non-S)
sb01box is offline   Reply With Quote
Old 06-08-2010, 05:32 PM   #3
sb01box-
kinda sounds like what happened to me. going from a stoplight i saw a cloud of smoke. i thought it was the bus next to me but it wasn't. i kept going and it got better...then, in less than a mile it got worse. the cel came on and the engine turned off. luckily, it was just before i got on the freeway. i coasted to a strip mall and parked. i noticed that there was oil coming out of the tailpipe.
what did it cost to repair your box? did you have to change out the O2 sensors?
Old 06-08-2010, 06:15 PM   #4
tonycarreon's Avatar
http://www.youtube.com/watch?v=CkQ8xFDDAxY
Old 06-08-2010, 08:00 PM   #5
Mine started making a squealing sound while at idle anytime else was silent. almost sounded like when a car is low on power steering fluid. $300 later at the dealer turned out to be the AOS.
boxster7614 is offline   Reply With Quote
Old 06-08-2010, 08:23 PM   #6
Originally Posted by silverboxter
sb01box-
no O2 sensor replacement. oil came out of the drain opening at the air filter box but none from the exhaust.
total of 1-1/2 quarts went up in smoke.
cost was with 90K service and keyfob. 2200 at local dealer. don't recall the breakdown but about 400 for AOS I think.
Old 06-08-2010, 08:41 PM   #7
Mine started with running a little rough during cold start which progressed on each start. Ran fine once the engine was warm. Then periodic smoke at start up. If I drove the car hard you would see a cloud of smoke behind you.
2008 Boxster S PDE2
cas951 is offline   Reply With Quote
Old 06-09-2010, 05:32 AM   #8
jcb986's Avatar
The most common failures are, white smoke coming out the exhaust and the engine running rough from the oil or the engine front will have a squeal coming out of the seal around the front of the crankshaft and this is usually is after the engine has warmed up. Also, you cannot easily remove the oil filler cap when the engine is running. A new AOS comes with the seal and boot for about $115. It takes about 2 hours. Failure of this part is common. I replaced mine and the top J-tube, left the bottom as is. Search here for AOS repair...there is one that goes step-by-step. also, here is Mike's DIY.
http://sites.google.com/site/mikefocke2/mikesporscheboxsterwebpages
Old Hippie Young Heart
Old 06-09-2010, 05:58 AM   #9
Anybody bother to install the motorsport version?
http://www.****************************************************.com/product/9XXSEP.html?Category_Code=986sport
Old 06-09-2010, 08:46 PM   #10
Just got the call. O2's need to be replaced...pricey! I'll keep you informed. Now I'm a little paranoid. My wife's '02S had some smoke at start up. It only has 30k miles. hmmmm
Old 06-10-2010, 08:37 PM   #11
They are attributing the smoke to the O2 sensors alone, then?
wanna986 is offline   Reply With Quote
Old 06-13-2010, 01:00 PM   #12
Got her back Thursday.
AOS
new plugs
4 O2 sensors
(MAF not needed)
$2k
Glad to have her back. My advice: If you suspect that your AOS is failing, get it changed out. You could save yourself $1200 in O2 sensors. Just my 2 cents. ; )
