Old 06-02-2010, 11:59 AM   #1
ChrisZang's Avatar
Originally Posted by 9mmkungfu
Sorry - I was referring to only the rear wheel rim widths when I mentioned 9.5/10 (I was planning to do an 8.5" front or possibly a 9").
I've seen quite a few others with 19" wheels, although that doesn't mean they're okay for usage. I wonder if anyone else has any input as to using 19s.
Ah, OK
but even with 9.5 in the rear you still might spacers, depends on the offset of the rim
Old 06-02-2010, 02:01 PM   #2
A friend of mine ran turbo 19x11 rear wheels on his '98 Boxster. He had to roll his fenders and used spacers but they did fit.
Although it can be done, unless you have wads of cash, I'd advise against it simply because of the cost of tires could put one in the poor house.....IMHO I think 18's are the sweet spot for looks and tire cost and choice.
Plus, you can use the money you saved from not having to purchase 19" tires and lower your car making the 18's look even better and probably have some $$$ left over for the other mods you will eventually end up doing....
- ian
idheaton is offline   Reply With Quote
Old 06-02-2010, 02:29 PM   #3
Johnny Danger's Avatar
I have considerable experience with regard to wheel applications. Rolling the fender notwithstanding, no way, no how will an 11 inch wheel fit on a 986 boxster.
Old 06-02-2010, 06:53 PM   #4
Question
I would be perfectly happy with a 9.5" or 10" wheel in the rear. But are most people running 18s? I didn't realize 19s weren't that popular with the 986 cars.
9mmkungfu is offline   Reply With Quote
Old 06-02-2010, 07:14 PM   #5
07 Carrera S Cab
Boxtaboy's Avatar
I run 18s with 8" front and 9.5" rears. No spacers. My guess is that most people actually run with the stock 17" wheels on the 986, and those who upgrade run with 18". The 986 was never designed to run with 19" wheels, but some have done it.
Old 06-02-2010, 09:05 PM   #6
ChrisZang's Avatar
forgive me if I am stating the obvious but not all rims are created equal, it's all about the offset. If a 9.5" Boxster wheel fits w/o spacers this does not mean that a 9.5" Carrera wheel will fit
Old 06-02-2010, 09:29 PM   #7
07 Carrera S Cab
Boxtaboy's Avatar
Absolutely...not all 9.5" wheels will fit without spacers. The offset is important.
Old 06-03-2010, 09:49 AM   #8
I think it's because when the Boxster first came along, it wasn't really designed to support a 19" wheel. Plus, the added weight and/or cost that a 19" wheel/tire entails is a negative to some with little or no benefit over 18s.
- ian
Old 06-03-2010, 11:21 AM   #9
I went with 18" 997 Turbo Replica from Ebay and loved them.
S3adrag0n
S3adrag0n is offline   Reply With Quote
Old 06-03-2010, 09:42 AM   #10
I am not an expert (nor do I play one on tv... ) but I personally saw the wheels on the car and my friend told me he rolled the fenders and used large spacers for clearance.
Unfortunately, I don't have any better images of the rear end, but these were 11" rears running 315/25/19s. They were Victor Equipment Lemans wheels as seen in the post below.
Opinions on rear spoiler
- ian
Old 06-03-2010, 12:07 PM   #11
There is absolutely no way that one could fit an 11 inch wheel on a 986 boxster, let alone with a 315 tire. The Lemans wheel is also available in a 9.5 . Perhaps, someone is mistaken on the size.
Old 06-03-2010, 03:56 PM   #12
Maybe they were 9.5s, I never actually measured his rear wheels but I can confirm without doubt that they were 19s and shod in 315s because I distinctly remember the $$$ signs that flashed in front of my eyes thinking about when the time came for him to replace the tires...
As to mistaken on size, my friend and the owner of the Boxster told me they were takes offs from a turbo (in the shop he was a technician) for a change to different wheels and that they were 11" wide. I know they were noticeably wider than the 18" Sport Designs I have on my car and I had no reason to doubt him.
It really makes no difference since the OP is more than likely not going to go this route anyway, I was just passing on some info I had. I apologize to the OP for the thread jack and any possible misinformation I might have passed on unintentionally to others, so in closing..... No, 19x11 wheels will not fit on your Boxster....
- ian
Old 06-03-2010, 05:41 PM   #13
I ran 19x9" in the front and 19x10" in the rear of my 2000 Boxster. i changed back to the stock 17" rims on the front and rear because my car didn't seem to have the torque to run the bigger rims without feeling noticeably sluggish in lower gears. maybe it's my perception but i can tell a difference in the "seat of the pants" feel between the bigger (heavier) rims and tires vs. the smaller (lighter) rims and tires. running the 19" rims + the a/c was not enjoyable at all. FWIW
Fletch986 is offline   Reply With Quote
