Old 04-30-2010, 07:40 AM   #1
rear tire wear
ok, the rim is trued up, new rubber is on. now I'm wondering about the wear on the old tires. outside couple inches was still looking good. middle was in the wear bars and the inside was down to the cords in places. looking at the car from the rear it seems like there is a little neg. camber. so... is this a normal wear pattern or do I need some kind of rear alignment? fronts are wearing evenly accross the tire. thanks for the inout.
02box is offline   Reply With Quote
Old 04-30-2010, 07:43 AM   #2
Alignment needed for street use.
Mike
04 Boxster S - Basalt/Savanna, 6sp, Carrera lites, hardtop
70 914-6 - Black over tan, original/stock
PCA since 1970
70Sixter is offline   Reply With Quote
Old 04-30-2010, 08:16 AM   #3
Not uncommon to wear on the inside since the suspension is independant. It will handle better with neg camber although an alignment will improve tire wear.
1997 Boxster 986
TechArt Championship Formula OZ Wheels,
TechArt Springs
TechArt Strut Brace Front and Rear
Technobrace (Thanks Pedro)
Michelin PS2
G2 Red Caliper Paint
DamageINC123 is offline   Reply With Quote
Old 05-01-2010, 11:54 AM   #4
That's exactly how the rears on mine wear.
2000 Boxster.
1997 Carrera 993.
986_Ron is offline   Reply With Quote
Old 05-01-2010, 05:32 PM   #5
need to drive the car harder to get more even tire wear...
kabel
Orlando - 99 BMW M Coupe (autocross toy), '11 Mazdaspeed 3 (dog hauler), '99 10AE Miata (the new daily driver)
kabel is offline   Reply With Quote
Old 05-02-2010, 12:22 PM   #6
Mine wear evenly, altho rt rear wears faster than left. If inside is wearing and outside is not, you have too much negative camber.
A lot of guys used to dial in neg camber at the rear for track work, esp A/X. Not sure about that with modern suspension geometry.
Mike
PCA since 1970
