Old 05-26-2010, 03:08 PM   #1
Cleaning foggy or yellowed headlights
I'm excited to try the baking soda/water method when I get home, see the following link. (http://www.ehow.com/how_4488636_clean-haze-off-car-headlights.html) I'm just curious if anyone's done this or had experience removing the yellow haze off their boxster headlights...any suggestions?
99 2.5L Boxster: 135,800 miles, AVIC-Z2 In-dash navigation/DVD receiver w/bypass switch, made and installed Pedro's hi flow air intake, custom laser engraved wind-stop, hacked convertible top relay, de snorkeled.
Pianohawk is offline   Reply With Quote
Old 05-26-2010, 04:02 PM   #2
I haven't used baking soda - seems a little too abrasive to me - but I have used plastic polish and buffing wheel to buff out headlights in the past. Auto parts stores generally sell a kit with a buffing wheel and plastic polish for under $20. This definitely did not result in a like-new appearance, but it was my sister-in-law's SUV, so whatever.
Were this my Boxster, I'd remove the lights and take them to a local body shop to be sanded and clear coated - there are a couple of places around here that do headlight restoration.
If you do wind up doing it yourself, post before and after pics!
1999 Carrera 4 • Aero kit • 4" UD Pulley
My Corvette doesn't leak oil... it sweats horsepower.
sd_boxster is offline   Reply With Quote
Old 05-26-2010, 04:09 PM   #3
Wet sand them with 1500 to 2000 grit sandpaper, and then polish with a plastic polish (such as the Mcguires Headlight Kit) and they'll look 1000% better.
Boxster S
Old 05-26-2010, 04:19 PM   #4
2001 RUF 3800S
violametallic-S-'s Avatar
I always thought the fogging was coming from the inside....
IG: RUF3800S
violametallic-S- is offline   Reply With Quote
Old 05-26-2010, 05:24 PM   #5
Just tried the baking soda method...
I followed the directions on http://www.ehow.com/how_4488636_clean-haze-off-car-headlights.html.
The before picture shows the results of Cascade Collision's $29.99 headlight restoration job. The after pic was taken immediately following the baking soda/water polish job my wife and I did tonight.
Maybe Cascade Collision didn't do as good a job as others probably would, but our baking soda and water concoction made a nice improvement.
If you give it a try let us know the results! (takes 5-15 minutes)
Before baking soda and water
After baking soda/water
Old 05-26-2010, 06:40 PM   #6
Pat
You might appreciate my write-up:
http://forums.audiworld.com/showthread.php?p=2627541
"Of all the extreme sports I've ever participated in- windsurfing, kite boarding, wake boarding, tow-in surfing and snowboarding- skiing, for me, made everything else easy."
-Chuck Patterson
Pat is offline   Reply With Quote
Old 05-27-2010, 07:01 AM   #7
Novus 1, 2 and 3
Works on headlights that have sat outside and develop that haze. I used nothing beyond a bit of abrasive #3, fine mix #2 and polish #1 using an old washcloth on my son's Mazda. Worked great. I happened to have the Novus around from its use on the rear plastic top window of my Boxster...whose top is at least 6 years old...maybe more...and which looks clear and new.
Old 05-27-2010, 07:13 AM   #8
As Mike said, I just use the plastic polish that I already had on hand for the back window.
It's Meguiar's PlastX as that was what was available at the local auto parts shop (~$9).
It's a mild polish, so it will not have much effect on really badly fogged or scratched plastic.
Aron
1997 Boxster
http://i40.tinypic.com/ax1qhz.jpg
Aron in Toronto is offline   Reply With Quote
Old 05-27-2010, 03:39 PM   #9
jcb986's Avatar
I have used some super fine paint rubbing compound. It's white in color and is a paste. Works real good, better if I use a high speed air buffer.
Old Hippie Young Heart
jcb986 is offline   Reply With Quote
Old 05-27-2010, 04:59 PM   #10
Toothpaste plus baking soda, on 10 year old headlight (Celica). Never touched with anything but soap/water before. I just had the driver's side headlight replaced (some lady pulled out in front of me). So now I'm taking the opportunity to try to find a good way to get the light looking new again.
I did a small spot on the headlight with Novus1. No real effect. Then I did the whole thing in toothpaste baking soda.
http://i50.tinypic.com/iwqef9.jpg
http://i46.tinypic.com/1440cxx.jpg
http://i47.tinypic.com/2iad5xg.jpg
'04 986 Aero - Seal Metallic Gray
Fabspeed: Maxflo Mufflers, Headers with sportcats, Tips; Alpine & Infinity sound
davemon is offline   Reply With Quote
Old 05-27-2010, 05:55 PM   #11
Quickurt's Avatar
I used Crystal View's kit over two years ago on Wifey's Civic and daughter's Prelude. Both were in terrible condition. Two years later they still look pretty good, especially the Prelude.
http://www.myheadlight.com/
This kiy includes a new polyurethane hardcoat to replace the protective coating that you sand/polish off to get your lenses clear again. Without this replacement coating, the lenses will deteriorate in rapid order after you polish them.
MY 135k miles CX7 lenses are starting to deteriorate, so I'm watching.......
A good UV protective wax, like DSX Defender II, also helps protect those expensive lenses. My good friend is the DSX distributor and his Accord's headlight lenses, the same age as my neighbor's, are in MUCH, MUCH better condition. He has had DSX Defender wax on them since he bought the used Accord. One wonders what they would look like had it been used since the car was new.........
http://dsxequiptech.com/dsx-defender-ii/ - full disclosure - if you read the fan application report, the second fan is my shop exhaust fan and the stuff definitely keeps the fan blades clean. I also use Defender II wax on my DD. It lasts FOREVER!! Over one year since the last application, our notorious Florida Love Bugs still wash right off the front of the car.
Sold - Black on Sand Beige 2006 S - 48K miles
18x8.5 and 10 OZ Alleggerita HLT Anthracite wheels and anthracite Cayman side grilles - lovingly adjusted Schnell Short Shift
Quickurt is offline   Reply With Quote
