Old 05-22-2010, 06:29 AM   #1
Optimum Tire Pressure
I have a 97 base with 16 inch wheels and I just had installed all-season z [w] rated Kumho's. The installer put 35 lbs all around stating that it provided the best balance between ride, comfort, and handling. The manual calls for something like 36 lbs in the rear and 30 lbs or so up front.
Should I go by the manual or is the installer's information more up to date, particularly considering my choice of an ultra high performance all-season tire?
Thanks!
Bradster
Bradster is offline   Reply With Quote
Old 05-22-2010, 09:16 AM   #2
The installer doesn't know Porsche
handling influencers.
Start with the 30/36 and vary in increments of no more than 2 PSI to see how you like it. I've had 4 brands/models of tires and find I like my tires 2 PSI harder all around than factory recommendations but you may fine the factory 30/36 just fine.
Old 05-22-2010, 10:34 AM   #3
Go with owner's manual recommendations.
In my experience, installers don't have specific knowledge about specific makes/models.
VGM911 is offline   Reply With Quote
Old 05-22-2010, 12:06 PM   #4
Thanks guys. I appreciate the feedback! Out with the air in the front.
