Old 05-20-2010, 02:01 PM   #1
Replacing boxster emblem
I am planning to replace the boxster emblem with a porsche crest badge.Would anyone know how to do it? Thanks in advance. Cheers
ermed911 is offline   Reply With Quote
Old 05-20-2010, 02:29 PM   #2
Emblem
I carefully sawed the old emblem off using dental floss as a saw.
The remaining adhesive was removed with a llittle WD-40 and careful rubbing.
Hope this helps.
JD BOXSTER
JDBOXSTER is offline   Reply With Quote
Old 05-20-2010, 02:34 PM   #3
Pat
This works just fine. Try to minimize the amount of WD-40, Goo Gone, etc. that is left over afterwards by giving that area of the car a good wash. Ensure you wax it, also.
"Of all the extreme sports I've ever participated in- windsurfing, kite boarding, wake boarding, tow-in surfing and snowboarding- skiing, for me, made everything else easy."
-Chuck Patterson
Pat is offline   Reply With Quote
Old 05-20-2010, 03:01 PM   #4
Hope this helps.
JD BOXSTER
Prior to utilizing the dental floss to remove the emblem, I used a hair dryer to soften the glue on the emblem, and it worked like a charm.
2003 Porsche Boxster S 3.2L l AASCO Lightweight Flywheel l FVD Brombacher ECU l FVD Brombacher 100 Cell Sport Catalytics l FVD Brombacher Sport Headers l GiroDisc 340mm FR Rotors l IPD Intake Plenum l Litronics l KW Variant 3 Coilovers l Porsche 997 75mm Throttle Body l Road Sport Supply Underdrive Pulley Kit l Sachs Stage 2 Racing Clutch Kit l TechArt Short Shift Kit l TechArt Power Flow Kit l TechArt Sport Exhaust.
Cartel is offline   Reply With Quote
Old 05-20-2010, 05:20 PM   #5
not only do I know how I have done it!
my tutorial on the project here
just a side note if you buy the badge from the factory you dont have to mess with finding hardware at various places like I did
