Old 05-16-2010, 04:33 PM   #1
Oil leak
Just changed the oil today and noticed a couple of drops on the driveway. Its not coming from the drain plug or filter. Its on the right side near just inside the right rear tire. I believe this is the side the AOS is on.
The oil gauge is showing to the upper line but not above it. Did I over fill it a little? It was not doing it before the oil change. Any help much appreciated.
1997 Boxster 986
TechArt Championship Formula OZ Wheels,
TechArt Springs
TechArt Strut Brace Front and Rear
Technobrace (Thanks Pedro)
Michelin PS2
G2 Red Caliper Paint
DamageINC123 is offline   Reply With Quote
Old 05-16-2010, 06:53 PM   #2
Can you get under it and take a look and a picture?
It might be the oil filler tube - mine leaked once and I had to replace the clamp.
2001 Boxster S
Desnorkled
Pioneer Avic D3
JL Audio 6.5 inch subs (in the door)
Pyramid 4 channel amp
chitowndad is offline   Reply With Quote
Old 05-17-2010, 05:30 AM   #3
Is it clean oil or dirty oil? Sounds like the oil fill tube to me. They tend to crack and will leak when adding oil.
amondc is offline   Reply With Quote
Old 05-17-2010, 05:50 AM   #4
Leak
The oil does is not very clean. I drove the car around last night. This morning I checked the floor and just a tiny drop. I wonder if its not coming from the AOS.
1997 Boxster 986
TechArt Springs
Michelin PS2
Old 05-17-2010, 05:13 PM   #5
I guess it was the filller hose. I must have spilled some oil. I was able to jack the car up and wipe all the hoses down. No more leak.
1997 Boxster 986
TechArt Springs
Michelin PS2
