Old 05-04-2010, 04:41 PM   #1
Seat Belt Warning Delete
I am installing aftermarket seats and 5 point harnesses in my 03 Boxster S and want to override the seat belt warning light and alarm.
Should I clip the wires at the female seat belt receptacle or is there a more elegant solution?
RTFTHVN is offline   Reply With Quote
Old 05-10-2010, 11:34 AM   #2
WELCOME!
I'm no help, but if for street car you might want to check local laws.
Mike
PCA since 1970
70Sixter is offline   Reply With Quote
Old 05-10-2010, 01:16 PM   #3
i,ve not done it but read that if you are tight with a mechanic at a dealer ...they can be bribed
extanker is offline   Reply With Quote
Old 05-10-2010, 03:29 PM   #4
I'm not sure exactly what you're trying to do, but if you remove the light bulb from the instrument cluster, you don't have to worry about the light. It's a simple DIY.
Viper5 is offline   Reply With Quote
Old 05-10-2010, 07:43 PM   #5
If you clip the wires in the seat you'll throw an airbag light. Viper's idea is the best yet.
Of course, black electrical tape over the front of the cluster in the glowing area is also another option if you're too lazy to take the cluster out
Old 05-10-2010, 10:39 PM   #6
Lil bastard's Avatar
It's really pretty simple. If you think about it, it'll come to you.
I'm not going to publish how to defeat the seatbelt warning system openly on the internet... don't want any widows' lawyers after me!
Cheers!
1976 BMW 2002
1990 BMW 325is
1999 Porsche Boxster
(gone, but not forgotten)
Old 05-10-2010, 11:40 PM   #7
seatbelt light
Is the female part of the seatbelt still on the car? If so, you can buy a plastic dummy to clip into it, this will act as a 'real' seatbelt and cancel the light/alarm. Otherwise removal of the bulb will be the second option, third option is to cut/bridge the circuit at the seat side plug depending on how the circuit works normally open or normally closed.
sickbananas is offline   Reply With Quote
Old 05-11-2010, 05:27 AM   #8
ChrisZang's Avatar
are you completely removing the original seat belts from the car?
