Old 04-06-2010, 05:40 PM   #1
any disadvantages to 19" wheels?
Are there any disadvantages to using 19" wheels? I assume the tires are more expensive. How do they affect the ride? What about road noise?
boxster1 is offline   Reply With Quote
Old 04-06-2010, 06:06 PM   #2
Perfectlap's Avatar
well you have to consider the weight of a 19" wheel which is more of factor than the size. The factory 18" turbo twists are 30 pounds. That's about as heavy as I would go. The factor 18" Carreras are 20 pounds, as are many forged ($$$) wheels which have the advantage of being pot-hole proof and light. With a big heavy cast alloy 19" you get the worst of both worlds. And not only are the tires pricier there are also fewer choices. If you ask me most 19" wheels make the Boxster look a little goofy. You'd have to lower the car (never mind that the Boxster is very well set up right out of the box without lowering) and lowering has its own issues on rough urban roads, things come loose, start to rattle, break, etc. As far as performance you're probably better off with a 17" light wheel with more sticky rubber to fill that wheel well.
BORN: March 2000 - FINLAND
Old 04-06-2010, 07:58 PM   #3
In general, bigger wheels are heavier as are the tires which means higher unsprung weight which will ulimately mean a slower car in a straight line. It usually also means worse gas mileage. It looks good though and usually fills the wheel well better.
Chapman had the right idea. Less weight, smaller cars, appropriate horsepower equals faster around the track.
Of course this is only my humble opinion.
JP308 is offline   Reply With Quote
Old 04-06-2010, 08:18 PM   #4
kyleturner2020's Avatar
mines on 19's and although I have nothing to compare it too, besides my previous Lexus with 17's....it's awesome!
2000 Boxster S
2007 H3
kyleturner2020 is offline   Reply With Quote
