Old 04-02-2010, 06:05 AM   #1
I have 18 x 10 rears with et 47mm. You will need to tie back the e-brake cable, but they do fit without rubbing the strut (my car is lowered about 1.5" from stock).
You should be fine with et 46, subject to your tire choice; fronts will be fine, as well.
The negative offset of 46mm from centerline brings the wheel closer to the inside; i.e. greater the negative value, the further in toward the strut. Conversely, anything less than et 46 will push the wheel out toward the fenders, causing another set of problems.
Here is a simple offset calculator that may help you understand the process:
http://www.1010tires.com/WheelOffsetCalculator.asp
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
Old 04-02-2010, 09:17 AM   #2
TriGem2k's Avatar
Send a message via AIM to TriGem2k
18x10 46mm will fit 100% without any issues. As mentioned be sure to tie back the e-brake cable and your set.
I run 18x10 48mm with 5mm porsche spacers (spacers just because I like the super wide rear stance) with 285/30/18 tires. No issues at all.
http://i46.tinypic.com/2qx0rqs.jpg
2001 Boxster Artic Silver / Black Interior
-GT3 Front Bumper w/ Lip
-Side Skirts
-Gemballa Exhuast and Cats
-O.Z. Racing 18" Wheels
--18X8.5Front 18X10 Rears
-Michilen PS Tires 225/40/18 & 285/30/18
-5mm Rear Spacers
-Porsche Door Sills
-H&R Springs
-Powerflow Intake
-B&M Short Shifter
-Pioneer Avic-F90BT Navigation
-Focal Polyglass 165VR3
-Alpine PDX 5 Amp
-Bose OEM Subwoofer & Midrange
-Audio Controld DQXS (DSP)
TriGem2k is offline   Reply With Quote
Old 04-02-2010, 09:53 AM   #3
Perfectlap's Avatar
Thanks guys,
How exactly do I tie back the e-brake and how do you keep it from slipping?
BORN: March 2000 - FINLAND
Old 04-02-2010, 02:36 PM   #4
07 Carrera S Cab
Boxtaboy's Avatar
Originally Posted by Perfectlap
Thanks guys,
A zip tie will work, but can work its way loose over time. There is, however, a factory clip made to keep the e-brake line out of the way. Installed them on each side, and they work great. Read this: http://www.ppbb.com/phorum/read.php?6,1454979,1454979#msg-1454979
Old 04-02-2010, 09:28 PM   #5
Perfectlap's Avatar
ah that's pretty cool...
i'm going to post the part number:
999.651.230.02
