Old 03-28-2010, 09:19 AM   #1
Infinity Kappa dashtop upgrade
Time: 1hr, complexity: Simple. Basic tools required: Hex socket, strong pliers, silicone sealant, small Philips screwdriver, cable stripper.
After doing some research I decided on the Infinity Kappa 42.9i co-ax speakers as the replacements for my dash-top speakers. I won't go into the reasons in depth - but they're on the Infinity website, but the main reasons were these speakers are almost designed for the modest upgrade (I'm planning 50watts RMS per channel) and are very efficient too. I'm not going for hi-fi, nor am I going for street bass, but 93dB/Watt is impressive.
Anyway, the procedure is fairly straightforward. There are plenty of guides on the web, but this is how I did it:
1) remove hex-screws with a tip. These should be hand-tight only.
2) Use a small screw driver to push the edge of the connector in to remove the socket. Curiously , this has a VW/Audi logo on it (!)
3) You may have a tweeter installed. Just snip the wires near the tweeter and leave it in situ, we won't be using it.
4) Thank your little helper, but tell him politely but firmly his help isn't needed
5) Don't let the fact that the paper coned original looks bigger...
6) Flip them over to see the obvious difference.
Gary H is offline   Reply With Quote
Old 03-28-2010, 09:21 AM   #2
7) We only require the mounting ring from the original , so cut all the way round...
8) and then seprate by cutting out the cone by the rubber ring surround
9) What you're left with looks simple, but is invaluable for a quick and easy fix:
10) you will need to cut the lugs down, approx half-way and go for a trial fitting. It's better to have a tight fit than a loose one - as the four lugs will be the securing points on to the mounting ring
11) Once your happy with the fit, hot glue/silicone the bottoms of the lugs, and pull up the mounting ring. Once the glue has gone off/set, use the foam supplied with the speakers to seal the edge the whole way round
12) I decided to get rid of as much of the dirty, dusty crumbly foam from the inside of the grill as I could:
13) Finally, re-assemble the speaker with the now attached mounting ring back onto the grill housing using the three screws that you removed to take off the speaker.
The Kappas have a lead with a +ive and -ive junction box so rather than try and re-use the old connector, I simply cut off the connector, bared back the wires and screwed them in to the junction box. IIRC Yellow and Yellow/brown and red and red/brown were the speaker wire colours, the brown stripe indicating negative.
Before remounting the speakers, I managed to stuff approx 12" square of acoustic wadding down the cavity.
14) AS a final touch, I prised off the infinity badges from the original grills and managed to get them glued to the car's.
Old 03-28-2010, 12:16 PM   #3
Awesome post! Seriously, thanks for this!
2003 Porsche Boxster - Arctic Silver
kerplunk is offline   Reply With Quote
Old 03-28-2010, 09:40 PM   #4
roadracer311's Avatar
Nice work! I love Infinity speakers! Especially Kappa's!
2003 Boxster S
1995 Ferrari F355 Spider
San Francisco, CA
roadracer311 is offline   Reply With Quote
Old 03-29-2010, 12:57 AM   #5
Christian H's Avatar
Great post Gary, one more for my "to do list"
Christian H is offline   Reply With Quote
Old 03-29-2010, 06:22 AM   #6
Nice work!
What did you use to cut up the outside mounting locations on the Kappas?
Old 03-29-2010, 07:58 AM   #7
Some heavy duty pliers (we refer to them as 'tin snips')
Another pic:
Old 03-29-2010, 08:09 AM   #8
Good write up Gary. I just did the same exact thing with some Polk DB401 speakers. One tip I would like to add is DONT drop the bit down your defroster duct!!! It's easy for that little bit to slip out of your fingers and slide in to the duct.
Fortunatly a little fishing line and magnet setup retrived it from the bowls of the dash but I think I was very lucky to get it. Maybe some painters tape or a cloth over the duct is a good idea....
chubert is offline   Reply With Quote
Old 03-29-2010, 08:03 PM   #9
Yep, a lot of us did that last year. There are a few posts back in october somewhere. Nice pics, you should see if the mod will put them over to the DIY section.
The rears were a little bit more tricky though. Here is a post of what I did. Hope it helps.
Dont know what happened to the pics.
http://www.987forum.com/forums/showthread.php?t=22449
I'll take my Guns, Religion, and Money; You can keep the "CHANGE" B.O.!!
SO, GROW A PAIR NANCY AND DRIVE IT LIKE YOU STOLE IT!!
http://i826.photobucket.com/albums/z...Main/MyBox.jpg
mptoledo is offline   Reply With Quote
Old 05-28-2010, 12:07 PM   #10
Just completed mine yesterday. Infinity 429I sound great much better than the original. One small remark, is that don't mix-up the right and left front grids they are NOT reversible. Took me half and hour to figure out....
http://www.boxsterforum.com/forums/a...chmentid=11471
MUST OWN ONE IN YOUR LIFETIME
2003 BOXSTER S 6SP, PMS, Lit's, 18" Carrera Lites
goodman is offline   Reply With Quote
Old 05-28-2010, 12:35 PM   #11
video
There's actually a video on Youtube that shows you how to do this. Maybe it'll help:
http://www.youtube.com/watch?v=W0LPyCoq5k8
Parts for sale: 4-spoke Steering wheel, air bag, and leather cover ($350 + shipping), Rear zipper storage bin ($100 + shipping), CDR-210 Factory OEM radio, casing, and keys ($100 + shipping), Hand brake handle and hand brake sensor ($50 + shipping), Manual factory leather shift knob ($Free + shipping)
Tranlm is offline   Reply With Quote
Old 05-30-2010, 05:26 PM   #12
Do 5 inch speakers fit instead of 4">
Also, why did you pick Infinity Kappa over other series (such as Reference or Kappa Perfect?
sdharmani is offline   Reply With Quote
Old 05-31-2010, 03:17 AM   #13
I am going to try the kappas in the dash. My 97 has 5 or 6 inch door speakers (aftermarket) that need to be replaced. Has any one tried something in the door that they liked?
Thanks.
Bradster is offline   Reply With Quote
Old 09-22-2010, 08:03 PM   #14
xtremecc's Avatar
great post Gary! this seems like a perfect speaker solution and a great weekend project! thanks!
xtremecc is offline   Reply With Quote
