Old 03-25-2010, 04:54 AM   #1
GTA_G20's Avatar
Need help removing speedometer
So I have a burnt bulb and Im wanting to fix this. I have everything unbolted, however there are three plugs that I cannot seem to remove. The first one seems to plug into the right side of the cluster I'm not sure how to remove this without breaking anything. Sorry I came from japanese land where you squeeze a tab and pull. I've never seen a clip like this. any help is appreciated
2006 Audi A4 Avant 2.0t Quattro
1997 Boxster Glacier White w/facelift(gone but not forgotten)
2004 Boxster S 550 Spyder Anniversary Edition
GTA_G20 is offline   Reply With Quote
Old 03-25-2010, 04:59 AM   #2
According to my Bentley book, if we are talking about the same connector, there is a lock lever which needs to be disengaged with a small screwdriver. It's a U shaped piece that straddles the entire assembly, it says to lift it up, swing lever to release, hope this helps good luck..
eightsandaces is offline   Reply With Quote
