Old 12-21-2002, 11:17 AM   #1
Reading Codes
Nology now sells a great little device you plug into your OBDII port (the plug near your fuse box) and into any PDA. It will read all the codes, plus can give you chassis dyno style performance numbers for your vehicle. Works great to see if the last tweak/ bolt on made any difference. Check it out.
PDA Dyno
gt3fx is offline   Reply With Quote
Old 12-22-2002, 06:19 PM   #2
I knew there had to be a reason I need to purchase a PDA -- Now I have one!!
Thanks!
ehljags is offline   Reply With Quote
