Old 02-27-2010, 07:42 AM   #1
SDBxstr's Avatar
faint knocking sound
hey guys i could use a little help. i have a 01 986 ( love the car) there is a faint knocking coming from the upper roller , i had it diagnosed by ipd here in san diego we both heard it using a stethascope and pinpointed sound coming from upper roller. purchased new roller installed myself unfortunately knock is still there. any ideas your help would be appreciated
thanks mark
SDBxstr is offline   Reply With Quote
Old 02-27-2010, 01:40 PM   #2
If you have a manual transmission, then you also a have a freewheel type alternator pulley. It will make some noise as the engine idle speed changes. Mine was making a lot of clicking, and made a screaming noise as it coasted after revving the engine. Replacing it solved the problem.
-james
'01 Boxster S, 51k miles
'05 Mazda 6 Grand Touring Wagon
yimmy149 is offline   Reply With Quote
Old 02-27-2010, 02:03 PM   #3
SDBxstr's Avatar
knocking sound
thanks for the reply, but the knocking sound was pinpointed with stethascope coming from upper drive belt roller . i replaced it but noise still there (only noticeable at idle) i have manual trans.
Old 09-29-2011, 07:28 PM   #4
Hey, did you figure out what was the cause of the knocking sound? I'm facing the same problem
01 Boxster - Lapis Blue - Aerokit II Daily Driver.
98 Pontiac sunfire - Winter beater- TRADED IT IN FOR 200 DOLLARS
2010 Honda Civic Coupe - Gunmetal Grey - Lease ended and returned
2011 Mercedes Benz GLK350 - Gunmetal Grey
ramo80 is offline   Reply With Quote
