Old 01-29-2010, 08:16 PM   #1
engine fault codes
So My 97 Boxster's engine fault lite is on and I got a code reader and came up with P1124 & P1126 anyone know what that means? Car runs fine but gas milage is pitiful @ 13 MPG! Gulp.
manxman is offline   Reply With Quote
Old 01-31-2010, 02:53 PM   #2
engine light
If you know someone who is a mechanic get him to do a diaganoitic using a program from laptop. That's what I did when I had to find my vacuum leak code
baileymc is offline   Reply With Quote
Old 01-31-2010, 05:25 PM   #3
P1124 Fuel pump relay output stage (Short to B+ / above upper limit / rich mixture threshold)
P1126 Oxygen sensing adaptation, lower load range, cyl's 1-3 (Short to B+ / above upper limit / rich mixture threshold)
