Old 01-10-2010, 11:54 AM   #1
Front plastic window seal has come away from the window - suggestions?
http://alloycarparts.co.uk/images/parts/porsche_seal_001.jpg
The plastic / rubber seal has come away from the window, and has let windscreen wash in through the gap a couple of times, so its no longer water tight.
Any suggestions on what can be done???
thanks for help in advance.
emohawk11 is offline   Reply With Quote
Old 01-10-2010, 12:27 PM   #2
If the plastic is in good shape, you can probably go to any autoglass shop to have it re-sealed.
If it's in bad shape, you can get a new one from the dealer, and then have an autoglass shop install it. Or if you don't care about the "factory" look, the shop will also have the generic stuff.
-james
'01 Boxster S, 51k miles
yimmy149 is offline   Reply With Quote
Old 01-10-2010, 12:58 PM   #3
The plastic looked in reasonable shape to me, but when I got to Autoglass they said the back had crumbled away.
They tried with a screwdriver to apply pressure and press the seal back into place, but its still loose.
When I asked for options;
1) leave as is (not ideal!)
2) replace seal, which I was told meant taking the windscreen out !? he then went on to say the windscreen may crack when taking it out, so a new windscreen & seal too.
any more thoughts? is it worth getting a second opinion?
