Old 03-18-2005, 06:04 AM   #1
Battery Options
My OEM battery has given up the fight and it needs to be replaced. What is the best option available for replacement? OEM, sealed battery or what?
Thanks,
John
John Gibson is offline   Reply With Quote
Old 03-18-2005, 06:22 AM   #2
I bought one from Autozone a few weeks back. It's maintenance free and it was least expensive at like $70 or so. Just go in and tell them what you need. It's easy to change, takes like 10 minutes. There's a core refund, so take your old battery with you.
BuffaloBoxster is offline   Reply With Quote
Old 03-18-2005, 08:39 AM   #3
I love the best DieHard batteries Sears sells. Sears are everywhere, so warranty replacement is easy down the road, and they have a no-questions-asked replacement policy.
They'll also diagnose a weak battery for free.
Old 03-18-2005, 08:47 AM   #4
Brucelee's Avatar
Don't forget that you will need to recode the radio.
Old 03-18-2005, 09:05 AM   #5
http://www.renntech.org/forums/index.php?showtopic=2950
Old 03-18-2005, 10:01 AM   #6
IF you have Costco in your area, get an Optima Red top. For 99 bucks, it is a good deal and great battery. HTH.
Later,
underDAWG is offline   Reply With Quote
Old 03-18-2005, 11:11 AM   #7
Porschekid's Avatar
Later,
True, I have one in my Altima and love it. But I hear it takes quite a bit of modification to fit in the Boxster.
http://www.thecarspace.com/photos/8/...1481113d25.jpg
When people risk their lives, shouldn't it be for something very important?
Well, it better be.
But what is so important about driving faster than anyone else?
Lots of people go through life doing things badly. Racing's important to men who do it well.
When you're racing, it's life. Anything that happens before or after is just waiting.
Porschekid is offline   Reply With Quote
Old 03-18-2005, 01:26 PM   #8
Brucelee's Avatar
The optima is much smaller than the stock battery. I don't know how you hold that baby down in the cubicle?
Old 03-18-2005, 08:03 PM   #9
I have a red top optima in mine, and all I did was remove the battery as well as the tray and affixed it to the trayso that the tray bolts could still be used to put both back in the car. There are little tabs on the sides of the optima that was perfect for drilling a small hole through to mount it. I also remember seeing several article regarding the making of an adapter plate to use the original mounting system, but I am not sure where I saw them.
porscheguy05 is offline   Reply With Quote
Old 03-19-2005, 06:34 AM   #10
Brucelee's Avatar
What is the advantage of the Optima anyway?
Old 03-19-2005, 08:01 PM   #11
There are a few advantages, which may mean nothing to some people though. They are a totally sealed battery which in theory could be mounted upside down in the front seat of your car. It emits absolutely no corrosive substance either. They are designed with some patented spira cell technololgy which is totally different than standard lead acid batteries. Many racers use them for the fact that they do not emit any harmful fumes as a lead acid battery will and they are also designed to take severe vibrations, which again probably does not make that much of a difference to the common driver. Also they can be completely ran down and recharged without suffering any damage to the battery. I cannot remember the exact figures, but they can be brought back from full discharge a rediculous amount of times. Check out their website if you are really interested, because I am only going off my memory. I just like the extra durability and reliability with the battery, and they are not that much more expensive.
Old 03-20-2005, 07:06 AM   #12
Brucelee's Avatar
Thanks. They look kinda cool too but of course, you can't see them in the box!
Old 03-20-2005, 07:51 AM   #13
Porscheguy is right. I use Optima battery exclusively for my offroad application. I can winch all day long and drain the battery death. I can charge it right back up. HTH.
Later,
