Old 12-31-2009, 04:28 PM   #1
987 radio
I just upgraded from a 97 986 to a 05 987 and I am loving it so far! I have a question for the 987 owners. I have the bose surround speakers. When I am not driving or when I stop it all works fine, but when i start driving it seems like the back speaker disconnects. (this only happens with radio, CD's work fine) Could it be a bad signal? If so, why would it work everytime I stop at a light?
juan986 is offline   Reply With Quote
Old 01-01-2010, 05:11 PM   #2
There is a microphone that tune the radio volume with the noise in the car (noise of wind when you ride) probably there is a little bug with that system witch would explain it change comportment when you stop
vipola is offline   Reply With Quote
Old 01-01-2010, 08:46 PM   #3
The CD changer and navigation module has a permanent power supply.I tapped off this from my dension. Since the dension allows you to control the i pod from the head unit ,I cannot see the need to go to the trouble of routing cables through to the cabin. There is planty of space to put an i pod or USB drive in the front compartment where the navigation/ CD unit sits.The dension now has bluetooth capability,if you have a PCM it emulates having the telephone option installed.The 987 and 997 are identical in terms of front end and wiring for the desnion.
nintendo dsi r4
stevewough is offline   Reply With Quote
