Old 12-06-2009, 12:43 PM   #1
jcb986's Avatar
New rotors, brakes & tires installed
I just finished and went on a test drive to bed the brakes in. Installed all 4 rotors by Balo with Mintex pads. Also, had new tires installed on my rims. The rotors and pads made a huge difference in stopping performance. I no longer feel that scrubbing from the brakes as before, I have smoother stops and when I have to stand on them she stops fast but smoothly. The tires are Falken 912's, which are more like Michellen Pilots. Nice smooth, very quite ride with a lot of bite of dry payment. Tested them on a nice hair pin turn at 50 mph she took it stride. Now, while out on the test I had a plug on one of the coil packs work loose. I have removed and cleaned all my plugs also replaced the spark plug tube seals on one side since they where showing oil around them. Now I need to clear the CHECK ENGINE light. Can I do this by disconnecting the battery and waiting a few minutes and them reconnect it. This works on some American cars. :dance:
Old 12-06-2009, 03:36 PM   #2
it may work but it doesnt work for all lights like AIRBAG wont clear... you can try just make sure you have your radio code handy first
Old 12-07-2009, 01:01 AM   #3
What year is your car?
The disconnecting the battery trick resets the computer on earlier model cars, like my 2000 S for example (tried and confirmed), but I believe that on the newer models it will not reset the computer.
Try it and see.
Daniel R is offline   Reply With Quote
Old 12-07-2009, 04:23 AM   #4
jcb986's Avatar
2000 S
Try it and see.
2000 S...did you have to put the radio code back in.
Old 12-07-2009, 04:29 AM   #5
any time power is disconnected from the radio (aka battery removal or radio removal) you will have to re-enter the radio code.
