Old 11-07-2009, 05:17 AM   #1
Unhappy Roof stuck down :(
I have a 1999 986, black.
The roof won't go back up after putting it down today. The motor won't engage, as if one of the cut-out switches isn't allowing the circuit to comeplete (in my humble opinion).
This happened before, except it got stuck halfway (!). I fiddled with everything I thought might be related, and I *think* I narrowed it down to a lever/switch mounted on the rearmost section of the void that holds the folded down roof, the 'bay' that the cover in front of the boot/trunk covers. This switch has some kind of lever on it that registers the roof is up or down....maybe....?
Anyhow the previous time I'd fiddled with that a bit and it the circuit seemed to be live again and the dashboard switch, once depressed, started the roof closing again.
So back to today.....the first nice day in ages, I decide to dare to open the roof again and spray some moisture repellant spray in the switch to see if it's just got damp.
The roof closed and opened a few times today but now back at home after driving about for maybe an hour, the roof now won't budge and the red light on the dash is on saying there is an error with the....'something to do with the roof'. I have a convertible fully open and live in the UK. Not good.
I can't get to the switch now the roof is fully down....or can I?
HELP! Ideas?
willd is offline   Reply With Quote
Old 11-07-2009, 05:48 AM   #2
dbw
roof probs
Happened to me this last summer and my problem was the micro switch in the parking brake - mine is a 2004. When I took it in to get fixed the tech showed me that it was possible sometimes to "jiggle" the parking brake handle around to get it to work. Another source of problems he said was the switch in the centre clasp where the roof grabs the window frame when latching.He said if you were stuck somewhere sometimes puching a pencil in there would cause the switch to work. There is a way to manually get it up.....it's in the owners manual but he suggested avoiding that if possible as sometimes things get broken. Good luck. For me my car is under a cpo warranty so Porsche picked up the tab.
dbw is offline   Reply With Quote
Old 11-07-2009, 09:10 AM   #3
Thanks.......although that's what I've had to do. I decided I had no choice but to manually dis-engage everything. The porsche manual makes it look vaguely easy to get those gas-strut-arms (whatever they are) off, but one of mine I had to use a full-size crow-bar. I don't think I've damaged anything, but I really didn't have much choice, it was stuck on fast. God knows how I'm going to get it back on!!
Anyway my roof is up, and I guess until I locate a Porsche specialist in my area (South Essex, UK) I can at least get it up and down manually.
I'll just finish this by saying to anyone who it happens to - I was ultra cautious about prising those bars off, but you have to give it some welly*. Lord alone know how some people do it from inside the car when the roof is stuck inthe UP position.
I'll be purchasing a mini-crow-bar I think to carry around with me......you gotta laugh, but it's going to be part of my Boxster toolkit now!
I formally welcome myself back into the world of proper sports-car ownership. I'm just hoping it's not going to be as painful or as costly as when I had the TVR Chimaera....surely it can't be....right?
*'A lot of effort'. British slang
Old 11-07-2009, 11:11 AM   #4
dbw
roof
My tech said the problem was not that common but it's still a pain in the caboose. Glad it worked out for you to get the roof up.
Dave
Old 11-08-2009, 08:14 AM   #5
Topless's Avatar
Check the top relay located in the footwell near your fuses. This happened once to me and I simply unplugged the relay, gave it a shake, plugged it back in and it worked again.
Old 11-08-2009, 10:10 AM   #6
Ok will take a look. Thanks for the tip.
