Old 10-29-2009, 06:58 PM   #1
husker boxster's Avatar
987 Steering Wheel Removal ???
I picked up a new leather Sport wheel on fleabay. Want to replace the Alcantara wheel currently on Punkin.
I've got a Bentley manual for 986s. Are there any differences in removing a 987 wheel vs a 986? Will the instructions be the same for either model? Anything I need to be aware of before I begin?
Thanks in advance.
1989 928 S4 5 spd - black
Old 10-30-2009, 04:48 AM   #2
Disconnect battery and wait a few minutes is key. Are you sure the fleabay wheel has a working airbag????
Old 10-30-2009, 07:33 AM   #3
Yeah, knew I should disconnect the battery.
The leather wheel didn't come with an airbag. Was planning to swap the airbag from my Alcantara wheel.
BTW...
I'm keeping the Alcantara wheel. If I ever decide to sell Punkin, she'll need that wheel.
Old 10-30-2009, 01:53 PM   #4
07 Carrera S Cab
Boxtaboy's Avatar
Here you go-
Steering wheel removal for a 987: http://www.planet-9.com/reviews/showproduct.php?product=149&cat=3
Old 10-30-2009, 07:13 PM   #5
Thanks Boxtaboy.
Great link. Doesn't look too complicated.
Old 11-04-2009, 03:53 PM   #6
Got the leather wheel installed this afternoon. A couple of items:
1. I didn't remove the ring around the airbag but removed the entire unit - airbag and ring. If I needed to remove the ring, I think it would be easier after taking the airbag out.
2. Was able to use the T55 torx socket to get the bolt off. There wasn't a 12mm hex head available at the parts store.
3. I also changed out the 3 trim pieces. Two are held on by screws but all three have 2 prongs / clips holding them in the wheel. Pry carefully with a screwdriver and they'll come off.
After reconnecting everything and starting it up, I get a PSM Failure light. Not sure if this will clear itself or if I have to have the dealer clear it. Will need to go to the dealer in a couple of days anyway as my maintenance clock is about to strike midnight.
All in all, this was pretty easy to do.
