Old 10-14-2009, 01:15 PM   #1
A/C compressor randomly cutting off
While the car is running with the A/C on, I can hear the compressor cutting off and on at random times. Is this something with the compressor itself, or could it be a pressure sensor?
blackbox is offline   Reply With Quote
Old 10-14-2009, 01:36 PM   #2
JAAY's Avatar
sounds like pressure or the compressor itself.. I really dont know though. I would check the refrigerant.
JAAY is offline   Reply With Quote
Old 10-14-2009, 01:53 PM   #3
Low refrigerant will definitely cause this - at least on a crappy Ford Tempo I once owned and a slightly less crappy Volvo 240 that came afterward.
I haven't charged the AC on a Boxster, but I assume it's DIYable, and it's a cheap first troubleshooting step since you can buy recharge kits at Target and WalMart...
1999 Carrera 4 • Aero kit • 4" UD Pulley
My Corvette doesn't leak oil... it sweats horsepower.
sd_boxster is offline   Reply With Quote
Old 10-14-2009, 02:58 PM   #4
Send a message via MSN to CJ_Boxster
Its definatly not anything you want to do on your own (DIY). You would need to take it to a shop that has the proper AC refill gauge/hose set, too much pressure/overfilling can cause leaks and failure of your AC system, Too little refridgerant/compressor oil and the compressor can fail.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
Old 10-14-2009, 03:34 PM   #5
Most likely a pressure switch or over or undercharged system. Have a shop hook it up to an ac machine to check pressures first. Then check the pressure switch.
Best of luck,
jd
Joe DiMonte
2001 Boxster S
Triple Black
AUDIOGUY is offline   Reply With Quote
