Old 10-06-2009, 12:43 PM   #1
2001 RUF 3800S
violametallic-S-'s Avatar
ABS light on even when car is not in motion
Lately my abs light has been coming on when cruising or waiting at a light. It comes and goes. Can it be a bearing issue?
violametallic-S- is offline   Reply With Quote
Old 10-06-2009, 01:22 PM   #2
Send a message via MSN to CJ_Boxster
Well other than checking the connection at the wheels, you can remove them and clean them off, since they are magnetic, metal shavings do cling to them. just wipe them all off and reinstall them and see if the light still comes on.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
Old 10-06-2009, 01:22 PM   #3
Assuming the brakes are mechanically good, it sounds more like a sensor issue at the caliper.
eightsandaces is offline   Reply With Quote
Old 10-07-2009, 12:45 AM   #4
pk2
CJ 2x. Im a broken record, but I bet half the electrical problems are he are bad. dirty/corroded connections. You can often just jiggle the connectors, slide them on and of a few times and you've got a conection.
PK
http://img87.imageshack.us/img87/163...58x6ir4.th.jpg
99 Supercharged 2.5L
pk2 is offline   Reply With Quote
